주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-BX510 Disk Tray Replacement
필요한 것
    1. Sony BDP-BX510 Disk Tray Replacement, Outer Cover: 1 단계, 이미지 1개 중 1개
      • Plug in the device to turn it on, then press the eject ( ⏏ ) button to open the tray.
      댓글 쓰기
    2. Sony BDP-BX510 Disk Tray Replacement: 2 단계, 이미지 2개 중 1개 Sony BDP-BX510 Disk Tray Replacement: 2 단계, 이미지 2개 중 2개
      • To remove the tray cover, hold both sides of the tray cover and gently apply a downward pressure.
      • Apply slightly more pressure to the left side until it unhooks then unhook the right side.
      • Close the disk tray by pressing the eject button again, then power off the device and unplug it.
      • Do not use too much force to remove the tray cover as you may break it.
      댓글 쓰기
    3. Sony BDP-BX510 Disk Tray Replacement: 3 단계, 이미지 2개 중 1개 Sony BDP-BX510 Disk Tray Replacement: 3 단계, 이미지 2개 중 2개
      • Turn to the back of the device.
      • Remove the two 7mm Phillips #2 screws.
      • Slide the two plastic covers on both sides of the device towards the back of the device to remove them.
      댓글 쓰기
    4. Sony BDP-BX510 Disk Tray Replacement: 4 단계, 이미지 3개 중 1개 Sony BDP-BX510 Disk Tray Replacement: 4 단계, 이미지 3개 중 2개 Sony BDP-BX510 Disk Tray Replacement: 4 단계, 이미지 3개 중 3개
      • Turn the device so you can see the bottom.
      • Unclip the three black plastic clips on the bottom of the device.
      • Unclip one clip on each side of the device.
      댓글 쓰기
    5. Sony BDP-BX510 Disk Tray Replacement: 5 단계, 이미지 1개 중 1개
      • Slide the cover forward to remove.
      댓글 쓰기
    1. Sony BDP-BX510 Disk Tray Replacement, Disk Tray: 6 단계, 이미지 2개 중 1개 Sony BDP-BX510 Disk Tray Replacement, Disk Tray: 6 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Pull the medium-sized 9 pin ribbon cable and the small 5 pin ribbon cable out of their connector in the motherboard.
      • Using tweezers, lift the black tab on the connector of the large 45 pin connector on the motherboard.
      • Pull the large 45 pin ribbon cable out of the connector in the motherboard.
      • Be very careful. The goal is to slightly lift the pin connector, not to completely detach it. Do not forcibly pull.
      댓글 쓰기
    2. Sony BDP-BX510 Disk Tray Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the 5mm Phillips #2 screw holding the metal brace above the disk tray.
      • Remove the two 5mm Phillips #2 screws that hold the disk tray to the metal case on the bottom.
      댓글 쓰기
    3. Sony BDP-BX510 Disk Tray Replacement: 8 단계, 이미지 3개 중 1개 Sony BDP-BX510 Disk Tray Replacement: 8 단계, 이미지 3개 중 2개 Sony BDP-BX510 Disk Tray Replacement: 8 단계, 이미지 3개 중 3개
      • Turn the device over to the backside.
      • Use tweezers or hands to take off the metal clasp for the metal brace near the center on the bottom of the device.
      댓글 쓰기
    4. Sony BDP-BX510 Disk Tray Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the metal brace then remove the disk tray.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Tae (Tim) Im
회원 가입일: 01/14/20
279 평판
안내서 3개를 작성함
York University, Team S1-G10, Woodhouse Winter 2020 York University, Team S1-G10, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G10
2 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 832
