주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-BX520 Bluetooth Module Replacement
필요한 것
  1. Sony BDP-BX520 Bluetooth Module Replacement, Disc Tray Cover: 1 단계, 이미지 1개 중 1개
    • Plug in the Blu-Ray player, then press the power button, making sure the Blu-Ray player is powered on.
    • Press the eject button on either the top of the Blu-Ray player or on the remote to open the disc tray.
    댓글 쓰기
  2. Sony BDP-BX520 Bluetooth Module Replacement: 2 단계, 이미지 1개 중 1개
    • Grab the sides of the disc tray cover and carefully pull each side upwards, starting with the left side. This will unhook the cover from the tray.
    댓글 쓰기
  3. Sony BDP-BX520 Bluetooth Module Replacement: 3 단계, 이미지 1개 중 1개
    • Close the disc tray, then power off and unplug the Blu-Ray player.
    댓글 쓰기
  4. Sony BDP-BX520 Bluetooth Module Replacement, Top Case: 4 단계, 이미지 1개 중 1개
    • Locate the three 8 mm screws on the back of the Blu-Ray player.
    • Using the Phillips #2 screwdriver, unscrew each of the screws and set them aside.
    댓글 쓰기
  5. Sony BDP-BX520 Bluetooth Module Replacement: 5 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull the top case back to remove it from the Blu-Ray player.
    댓글 쓰기
  6. Sony BDP-BX520 Bluetooth Module Replacement, Front Panel: 6 단계, 이미지 1개 중 1개
    • Insert the nylon or metal spudger under the clip on the side near the front of the device. Lift the clip so it is free from the device.
    • Lifting these clips may require you to hold one clip open while you move on to the next clip.
    댓글 쓰기
  7. Sony BDP-BX520 Bluetooth Module Replacement: 7 단계, 이미지 1개 중 1개
    • Flip device over so the bottom faces you.
    • Insert the nylon or metal spudger and lift the two clips on the bottom of the device.
    댓글 쓰기
  8. Sony BDP-BX520 Bluetooth Module Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the clip on the opposite side of the device with the nylon or metal spudger.
    댓글 쓰기
  9. Sony BDP-BX520 Bluetooth Module Replacement: 9 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement: 9 단계, 이미지 2개 중 2개
    • Grasp the front case firmly and lift from the rest of the device.
    • Lifting may require some force.
    댓글 쓰기
  10. Sony BDP-BX520 Bluetooth Module Replacement, Port Board: 10 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement, Port Board: 10 단계, 이미지 2개 중 2개
    • When handling circuit boards like the motherboard and port board, make sure to only touch them on the sides.
    • Locate the large ribbon cable connecting the port board to the motherboard.
    • Detach the cable from the motherboard by carefully pulling upward on the cable.
    댓글 쓰기
  11. Sony BDP-BX520 Bluetooth Module Replacement: 11 단계, 이미지 1개 중 1개
    • Using the Phillips #2 screwdriver, unscrew the silver, 8mm screw holding the board in place.
    댓글 쓰기
  12. Sony BDP-BX520 Bluetooth Module Replacement: 12 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement: 12 단계, 이미지 2개 중 2개
    • Using the nylon or metal spudger, carefully unclip the port board from the side of the player.
    댓글 쓰기
  13. Sony BDP-BX520 Bluetooth Module Replacement: 13 단계, 이미지 1개 중 1개
    • Carefully pull the port board free from the Blu-Ray player.
    댓글 쓰기
  14. Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: 14 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement, Bluetooth Module: 14 단계, 이미지 2개 중 2개
    • Pull the small 5 pin ribbon cable out of its connector on the motherboard.
    댓글 쓰기
  15. Sony BDP-BX520 Bluetooth Module Replacement: 15 단계, 이미지 1개 중 1개
    • Using a Phillips #2 screwdriver, remove the silver 8 mm screw attaching the Bluetooth module to the front of the case.
    댓글 쓰기
  16. Sony BDP-BX520 Bluetooth Module Replacement: 16 단계, 이미지 2개 중 1개 Sony BDP-BX520 Bluetooth Module Replacement: 16 단계, 이미지 2개 중 2개
    • Remove the Bluetooth module from the case.
    • Make sure to only touch the sides of the Bluetooth module when removing it from the case.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Gregory Pellegrino
회원 가입일: 02/02/15
405 평판
안내서 2개를 작성함
Cal Poly, Team 8-41, Amido Winter 2015 Cal Poly, Team 8-41, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G41
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 29
전체 시간: 683
