주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-BX620 Power Module Replacement
필요한 것
    1. Sony BDP-BX620 Power Module Replacement, Outer Cover: 1 단계, 이미지 2개 중 1개 Sony BDP-BX620 Power Module Replacement, Outer Cover: 1 단계, 이미지 2개 중 2개
      • Power on the device, eject the disk tray, and power off the device.
      • Turn the device over.
      • Lightly apply downward pressure on the black covering on the disk tray until it comes off.
      • Caution, applying too much pressure can break the black covering.
      댓글 쓰기
    2. Sony BDP-BX620 Power Module Replacement: 2 단계, 이미지 2개 중 1개 Sony BDP-BX620 Power Module Replacement: 2 단계, 이미지 2개 중 2개
      • Turn the device around.
      • Using a Phillips screw driver, remove the screws on both ends of the device circled red in the image.
      • Slide the side covers on either side towards the back of the device.
      • There is a back cover on either side of the device.
      댓글 쓰기
    3. Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 3개 중 1개 Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 3개 중 2개 Sony BDP-BX620 Power Module Replacement: 3 단계, 이미지 3개 중 3개
      • This step might require someone to help unclasping the plastic clips.
      • Turn the device so that the bottom is facing up.
      • In the bottom, unclip the three plastic clips circled in red.
      • On either side, unclip the plastic clip circled in red
      • Slide the black covering forwards to remove.
      • All five clips have to be unclasped for the covering to be removed.
      • Careful not to break the plastic clips when putting it back on.
      댓글 쓰기
    1. Sony BDP-BX620 Power Module Replacement, Power Module: 4 단계, 이미지 1개 중 1개
      • Gently pull on up on the power cord to unlatch it from the metal body of the device.
      댓글 쓰기
    2. Sony BDP-BX620 Power Module Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the cable connecting the Power Port to the Motherboard by pulling up.
      • It may be difficult to remove. Pull from the plastic part and not the wiring to prevent the wiring from breaking.
      댓글 쓰기
    3. Sony BDP-BX620 Power Module Replacement: 6 단계, 이미지 1개 중 1개
      • Remove both screws using the Phillips screw driver.
      댓글 쓰기
    4. Sony BDP-BX620 Power Module Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the Power Module up from the side. See picture.
      • Pull up and away to remove the Power Module
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Axel Cruz Jimenez
회원 가입일: 10/05/16
207 평판
안내서 3개를 작성함
USF Tampa, Team 1-6, Lacy Fall 2016 USF Tampa, Team 1-6, Lacy Fall 2016 회원
USFT-LACY-F16S1G6
4 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 28
전체 시간: 541
