주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony BDP-S1 Fan Replacement
필요한 것
    1. Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 1개 Sony BDP-S1 Fan Replacement, Sony BDP-S1: Getting inside the device: 1 단계, 이미지 2개 중 2개
      • Remove the 12mm screws with the Philips #2 screwdriver which keep the plastic panels in place.
      • Don't forget, there are two more 12mm screws on the other side as well.
      댓글 쓰기
    2. Sony BDP-S1 Fan Replacement: 2 단계, 이미지 3개 중 1개 Sony BDP-S1 Fan Replacement: 2 단계, 이미지 3개 중 2개 Sony BDP-S1 Fan Replacement: 2 단계, 이미지 3개 중 3개
      • First, remove the three 12mm black screws holding the top panel on (Phillips #2).
      • Then, remove the two 12mm black screws - one on each side of the back of the device - holding the top panel on.
      • Lastly, remove the three 12mm black screws on each side of device.
      댓글 쓰기
    3. Sony BDP-S1 Fan Replacement: 3 단계, 이미지 3개 중 1개 Sony BDP-S1 Fan Replacement: 3 단계, 이미지 3개 중 2개 Sony BDP-S1 Fan Replacement: 3 단계, 이미지 3개 중 3개
      • Potential for device damage: Carefully lift up the top panel, because there are two blue ribbon cables that must be disconnected before removing the panel, and we do NOT want them to break.
      • After gently disconnecting the two ribbon cables (you can just pull them out with your hand), take the top off and set it to the side.
      댓글 쓰기
    4. Sony BDP-S1 Fan Replacement: 4 단계, 이미지 3개 중 1개 Sony BDP-S1 Fan Replacement: 4 단계, 이미지 3개 중 2개 Sony BDP-S1 Fan Replacement: 4 단계, 이미지 3개 중 3개
      • After the top is off, you'll see that there are two metal bars that go across the top of the device.
      • Remove each bar by unscrewing the two 10mm silver screws on each end.
      댓글 쓰기
    1. Sony BDP-S1 Fan Replacement, Fan: 5 단계, 이미지 3개 중 1개 Sony BDP-S1 Fan Replacement, Fan: 5 단계, 이미지 3개 중 2개 Sony BDP-S1 Fan Replacement, Fan: 5 단계, 이미지 3개 중 3개
      • First we need to unscrew the fan from before we can remove it.
      • Remove both copper colored 10mm screws with a #2 phillips screwdriver.
      • As you remove the second screw, pull the fan inward to remove it from the remainder of the case. It should now only be connected to the case through a cable attached to the circuit board.
      • The disk drive is removed in the pictures, however this is not necessary to replace the fan and can be ignored.
      댓글 쓰기
    2. Sony BDP-S1 Fan Replacement: 6 단계, 이미지 3개 중 1개 Sony BDP-S1 Fan Replacement: 6 단계, 이미지 3개 중 2개 Sony BDP-S1 Fan Replacement: 6 단계, 이미지 3개 중 3개
      • We will now completely remove the fan from the player.
      • Carefully detach the cable from the fan to the circuit board by pulling on the cable connecting the fan to the circuit board.
      • You are now ready to install the new fan!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Nicolas Kennedy
회원 가입일: 01/26/14
111 평판
안내서 1개를 작성함
Cal Poly, Team 9-30, Maness Winter 2014 Cal Poly, Team 9-30, Maness Winter 2014 회원
CPSU-MANESS-W14S9G30
3 회원들
안내서 15개를 작성함
2가이드 댓글
We're can i get a replacement fan for my Blu- ray player model BDV-E4100. HEEEEELP PLEASE.
darren cottenham - 답글 공유
Where can I get a replacement fan for my blue-ray player.
Christopher Meriweather - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 40
전체 시간: 3,296
