주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony CCD-TR81 Microphone Casing Replacement
필요한 것
    1. Sony CCD-TR81 Microphone Casing Replacement, Disassembling Sony CCD-TR81 Battery: 1 단계, 이미지 1개 중 1개
      • Lift viewfinder to access battery pack.
      댓글 쓰기
    2. Sony CCD-TR81 Microphone Casing Replacement: 2 단계, 이미지 2개 중 1개 Sony CCD-TR81 Microphone Casing Replacement: 2 단계, 이미지 2개 중 2개
      • Press the battery release button.
      • While pushing the battery button, slide the battery to the left.
      댓글 쓰기
    3. Sony CCD-TR81 Microphone Casing Replacement: 3 단계, 이미지 1개 중 1개
      • Pull the battery pack out of the video camera.
      댓글 쓰기
    1. Sony CCD-TR81 Microphone Casing Replacement, Outer Case: 4 단계, 이미지 3개 중 1개 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: 4 단계, 이미지 3개 중 2개 Sony CCD-TR81 Microphone Casing Replacement, Outer Case: 4 단계, 이미지 3개 중 3개
      • Open the cassette cover.
      • Unscrew 14 screws located on the outer casing. Three are located on the top face 2x6.8mm and 1X4.54mm, three on the left face 1x4.54mm,1x5.3mm and seven on the bottom face 5x4.54mm and 2x6.77mm.
      댓글 쓰기
    2. Sony CCD-TR81 Microphone Casing Replacement: 5 단계, 이미지 2개 중 1개 Sony CCD-TR81 Microphone Casing Replacement: 5 단계, 이미지 2개 중 2개
      • Remove five screws from the right side, from bottom to top, 3x4.54mm 2x5.70mm.
      • Remove the single 4.5 mm screw from the backside.
      댓글 쓰기
    3. Sony CCD-TR81 Microphone Casing Replacement: 6 단계, 이미지 1개 중 1개
      • Pull off the plastic tape cover by lifting it up and out of the camera base.
      댓글 쓰기
    4. Sony CCD-TR81 Microphone Casing Replacement: 7 단계, 이미지 1개 중 1개
      • Disconnect the mic assembly by pulling it away from the camera base.
      • Do not pull too hard as the wires are still connected.
      댓글 쓰기
    5. Sony CCD-TR81 Microphone Casing Replacement: 8 단계, 이미지 1개 중 1개
      • Pull the bottom part of the case away from the camera.
      댓글 쓰기
    6. Sony CCD-TR81 Microphone Casing Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the three 4.5 mm screws from the right face of the video camera.
      댓글 쓰기
    7. Sony CCD-TR81 Microphone Casing Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the single 3.6 mm screw at the front of the video camera on the circuit board.
      댓글 쓰기
    8. Sony CCD-TR81 Microphone Casing Replacement: 11 단계, 이미지 1개 중 1개
      • Pull the audio/video inputs underneath the microphone assembly. The inputs should still be connected to the circuit board.
      댓글 쓰기
    9. Sony CCD-TR81 Microphone Casing Replacement: 12 단계, 이미지 1개 중 1개
      • Remove two remaining 3.6 mm case screws from the front of the camera.
      댓글 쓰기
    10. Sony CCD-TR81 Microphone Casing Replacement: 13 단계, 이미지 2개 중 1개 Sony CCD-TR81 Microphone Casing Replacement: 13 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Using metal tweezers, pull out the plastic connector box on the front side.
      • Again use metal tweezers to pull out the connection box on the bottom of the camera. The right side of the case can now be removed by pulling it to the right.
      댓글 쓰기
    1. Sony CCD-TR81 Microphone Casing Replacement, Microphone Casing: 14 단계, 이미지 1개 중 1개
      • Unscrew the blue screw behind microphone and remove it from the video camera 1x3.6mm.
      댓글 쓰기
    2. Sony CCD-TR81 Microphone Casing Replacement: 15 단계, 이미지 1개 중 1개
      • Pull the circuit board up and away from the microphone case.
      댓글 쓰기
    3. Sony CCD-TR81 Microphone Casing Replacement: 16 단계, 이미지 1개 중 1개
      • Pull up metal brackets with plastic removal tool.
      댓글 쓰기
    4. Sony CCD-TR81 Microphone Casing Replacement: 17 단계, 이미지 1개 중 1개
      • With the plastic removal tool, pry up the microphone housing units. This will allow access to the camcorder microphone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Austin Winther
회원 가입일: 01/24/11
4 평판
안내서 1개를 작성함
Cal Poly, Team 11-25, Maness Winter 2011 Cal Poly, Team 11-25, Maness Winter 2011 회원
CPSU-MANESS-W11S11G25
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 18
전체 시간: 1,613
