주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony CFD-8 Front Panel Replacement
필요한 것
  1. Sony CFD-8 Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 1개 Sony CFD-8 Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 2개 Sony CFD-8 Front Panel Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
    댓글 쓰기
  2. Sony CFD-8 Front Panel Replacement: 2 단계, 이미지 2개 중 1개 Sony CFD-8 Front Panel Replacement: 2 단계, 이미지 2개 중 2개
    • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
    댓글 쓰기
  3. Sony CFD-8 Front Panel Replacement, Front Panel: 3 단계, 이미지 3개 중 1개 Sony CFD-8 Front Panel Replacement, Front Panel: 3 단계, 이미지 3개 중 2개 Sony CFD-8 Front Panel Replacement, Front Panel: 3 단계, 이미지 3개 중 3개
    • Hold the boombox handle at an angle to access the screws behind the CD player.
    • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
    댓글 쓰기
  4. Sony CFD-8 Front Panel Replacement: 4 단계, 이미지 2개 중 1개 Sony CFD-8 Front Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
    • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
    댓글 쓰기
  5. Sony CFD-8 Front Panel Replacement: 5 단계, 이미지 3개 중 1개 Sony CFD-8 Front Panel Replacement: 5 단계, 이미지 3개 중 2개 Sony CFD-8 Front Panel Replacement: 5 단계, 이미지 3개 중 3개
    • Gently separate the front panel from the back panel.
    • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
    • Remove the front panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Andrew Kleve
회원 가입일: 10/12/14
271 평판
안내서 2개를 작성함
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G38
5 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 12
지난 30일: 45
전체 시간: 4,199
