주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony CFD-8 Motor Belt Replacement
필요한 것
    1. Sony CFD-8 Motor Belt Replacement, Battery: 1 단계, 이미지 3개 중 1개 Sony CFD-8 Motor Belt Replacement, Battery: 1 단계, 이미지 3개 중 2개 Sony CFD-8 Motor Belt Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
      • Be sure to unplug the boombox from the wall before attempting to open it for repair.
      댓글 쓰기
    2. Sony CFD-8 Motor Belt Replacement: 2 단계, 이미지 2개 중 1개 Sony CFD-8 Motor Belt Replacement: 2 단계, 이미지 2개 중 2개
      • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
      • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
      댓글 쓰기
    1. Sony CFD-8 Motor Belt Replacement, Front Panel: 3 단계, 이미지 3개 중 1개 Sony CFD-8 Motor Belt Replacement, Front Panel: 3 단계, 이미지 3개 중 2개 Sony CFD-8 Motor Belt Replacement, Front Panel: 3 단계, 이미지 3개 중 3개
      • Hold the boombox handle at an angle to access the screws behind the CD player.
      • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
      댓글 쓰기
    2. Sony CFD-8 Motor Belt Replacement: 4 단계, 이미지 2개 중 1개 Sony CFD-8 Motor Belt Replacement: 4 단계, 이미지 2개 중 2개
      • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
      • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
      댓글 쓰기
    3. Sony CFD-8 Motor Belt Replacement: 5 단계, 이미지 3개 중 1개 Sony CFD-8 Motor Belt Replacement: 5 단계, 이미지 3개 중 2개 Sony CFD-8 Motor Belt Replacement: 5 단계, 이미지 3개 중 3개
      • Gently separate the front panel from the back panel.
      • Remove the two connections holding the front panel to boombox.
      • One connection is located on the upper left hand side of the main circuit board.
      • The other is a large white strip slightly to the right of the cassette player.
      • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
      • Remove the front panel.
      댓글 쓰기
    1. Sony CFD-8 Motor Belt Replacement, Remove Gear Assembly: 6 단계, 이미지 1개 중 1개
      • Unscrew the 3x12 screws circled in the photo using a #1 Phillips screwdriver.
      댓글 쓰기
    2. Sony CFD-8 Motor Belt Replacement, Disconnect Wires: 7 단계, 이미지 1개 중 1개
      • Carefully disconnect the wire connection by pulling at its base.
      댓글 쓰기
    3. Sony CFD-8 Motor Belt Replacement, Remove Motor: 8 단계, 이미지 3개 중 1개 Sony CFD-8 Motor Belt Replacement, Remove Motor: 8 단계, 이미지 3개 중 2개 Sony CFD-8 Motor Belt Replacement, Remove Motor: 8 단계, 이미지 3개 중 3개
      • Unscrew the 5mm screw shown in the photo.
      • Note the small latch on the side of assembly as you remove the motor.
      댓글 쓰기
    4. Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: 9 단계, 이미지 2개 중 1개 Sony CFD-8 Motor Belt Replacement, Replace Motor Belt: 9 단계, 이미지 2개 중 2개
      • Remove the motor belt from its axle.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Wil Gilbreath
회원 가입일: 10/14/14
205 평판
안내서 1개를 작성함
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G38
5 회원들
안내서 21개를 작성함
4가이드 댓글
need belt for cassette replace
joe jefferson - 답글 공유
need the belt for the cassette player
First, be sure to have a #1 pt screwdriver with at least a 5” shaft(not counting the handle) length. Second, pay attention to where the screws under the handle are located. Third, mark the top of the connectors with a sharpie or such instrument to be sure you are replacing the connector in the correct position.
Don Gunkel - 답글 공유
Here's some information about the belts needed, which may be especially useful if your old belts have turned to goo like mine! Two identical belts are needed: the Sony part number is 3-362-989-01, and generic names appear to include SBO5.2 and SCY5.2. It's a square belt with 1 mm thickness and an inside diameter of 5.2 inches. I found that the most economical way to purchase these was to get a bulk bag of 1 mm square belts of mixed length.
SandStone - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 108
전체 시간: 14,948
