주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony CFD-8 Speaker Replacement
필요한 것
    1. Sony CFD-8 Speaker Replacement, Front Panel: 1 단계, 이미지 3개 중 1개 Sony CFD-8 Speaker Replacement, Front Panel: 1 단계, 이미지 3개 중 2개 Sony CFD-8 Speaker Replacement, Front Panel: 1 단계, 이미지 3개 중 3개
      • Hold the boombox handle at an angle to access the screws behind the CD player.
      • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
      댓글 쓰기
    2. Sony CFD-8 Speaker Replacement: 2 단계, 이미지 2개 중 1개 Sony CFD-8 Speaker Replacement: 2 단계, 이미지 2개 중 2개
      • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
      • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
      댓글 쓰기
    3. Sony CFD-8 Speaker Replacement: 3 단계, 이미지 3개 중 1개 Sony CFD-8 Speaker Replacement: 3 단계, 이미지 3개 중 2개 Sony CFD-8 Speaker Replacement: 3 단계, 이미지 3개 중 3개
      • Gently separate the front panel from the back panel.
      • Remove the two connections holding the front panel to boombox.
      • One connection is located on the upper left hand side of the main circuit board.
      • The other is a large white strip slightly to the right of the cassette player.
      • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
      • Remove the front panel.
      댓글 쓰기
    1. Sony CFD-8 Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 1개 Sony CFD-8 Speaker Replacement, Speaker: 4 단계, 이미지 2개 중 2개
      • Use a 14cm Phillips #1 screwdriver to remove the four respective screws attaching the left and right speakers to the front panel.
      댓글 쓰기
    2. Sony CFD-8 Speaker Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the speakers from the front panel.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Liam Kirsh
회원 가입일: 10/14/14
197 평판
안내서 1개를 작성함
Cal Poly, Team 10-38, Amido Fall 2014 Cal Poly, Team 10-38, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G38
5 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 35
전체 시간: 3,881
