주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony CPF-IP001 Subwoofer Replacement
필요한 것
  1. Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: 1 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement, Subwoofer Housing Disassembly: 1 단계, 이미지 2개 중 2개
    • Remove fourteen 8 mm Phillips #2 screws from the bottom of the subwoofer.
    • Once all of the screws are removed, the cover can be taken off using a metal spudger.
    댓글 쓰기
  2. Sony CPF-IP001 Subwoofer Replacement: 2 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 2 단계, 이미지 2개 중 2개
    • Remove eight 14 mm Phillips #2 screws holding the circuit board in place.
    • Using the plastic opening tool, carefully remove the circuit board.
    • There will be 3 wires connected to the opposite side of the circuit board. Be careful not to pull the board out of the device too far and damage these wires.
    댓글 쓰기
  3. Sony CPF-IP001 Subwoofer Replacement: 3 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the first of the three wires by squeezing the clip and pulling it out.
    • After disconnecting the first wire, the two attached wires can be more easily accessed.
    댓글 쓰기
  4. Sony CPF-IP001 Subwoofer Replacement: 4 단계, 이미지 3개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 4 단계, 이미지 3개 중 2개 Sony CPF-IP001 Subwoofer Replacement: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the wire furthest to the left by squeezing the clip and pulling it out.
    • Detach the third wire by carefully using the tweezers.
    • The circuit board is now completely detached and can be set aside.
    댓글 쓰기
  5. Sony CPF-IP001 Subwoofer Replacement: 5 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 5 단계, 이미지 2개 중 2개
    • Remove six 8 mm Phillips #2 screws.
    • Slide the side panel with the power cord out from the housing.
    • The side panel with the power cord will come out as a whole unit with the subwoofer air tunnel.
    댓글 쓰기
  6. Sony CPF-IP001 Subwoofer Replacement, Subwoofer: 6 단계, 이미지 1개 중 1개
    • Remove two 8 mm Phillips #2 screws holding the side panel in place.
    댓글 쓰기
  7. Sony CPF-IP001 Subwoofer Replacement: 7 단계, 이미지 1개 중 1개
    • Remove eight 8 mm Phillips #2 screws holding the subwoofer tray to the housing.
    댓글 쓰기
  8. Sony CPF-IP001 Subwoofer Replacement: 8 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 8 단계, 이미지 2개 중 2개
    • Using a metal spudger, slightly peel back the plastic the has been glued to the tray and the housing.
    • Slide the tray containing the subwoofer out of the housing.
    댓글 쓰기
  9. Sony CPF-IP001 Subwoofer Replacement: 9 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 9 단계, 이미지 2개 중 2개
    • After removing the tray, flip it over and you will find four screws connecting the subwoofer.
    • Remove four 7.5 mm Phillips #2 screws.
    댓글 쓰기
  10. Sony CPF-IP001 Subwoofer Replacement: 10 단계, 이미지 2개 중 1개 Sony CPF-IP001 Subwoofer Replacement: 10 단계, 이미지 2개 중 2개
    • The subwoofer has now been removed from the device and can be replaced.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Mike Bolton
회원 가입일: 04/14/15
473 평판
안내서 4개를 작성함
Cal Poly, Team 6-14, Maness Spring 2015 Cal Poly, Team 6-14, Maness Spring 2015 회원
CPSU-MANESS-S15S6G14
4 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 48
전체 시간: 1,136
