주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-Shot DSC-W830 Button Board Replacement
필요한 것
    1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide the lock at the bottom of the camera to "Open".
      • The door to the battery pack is spring loaded.
      댓글 쓰기
    2. Sony Cyber-Shot DSC-W830 Button Board Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the blue clip up and away from the battery.
      댓글 쓰기
    3. Sony Cyber-Shot DSC-W830 Button Board Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the battery.
      댓글 쓰기
    1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Button Board Replacement, Front and Back Panel: 4 단계, 이미지 3개 중 3개
      • Remove the six 3.5mm Phillips #000 screws.
      • Rotate the lock away from the camera.
      댓글 쓰기
    2. Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Button Board Replacement: 5 단계, 이미지 3개 중 3개
      • Pry the device open with the plastic opening tool.
      • There are two clips that help prevent the front panel from separating.
      댓글 쓰기
    3. Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 3개 중 1개 Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 3개 중 2개 Sony Cyber-Shot DSC-W830 Button Board Replacement: 6 단계, 이미지 3개 중 3개
      • Remove the two plastic spacers between the front and the back panels.
      • The spacers may fall out when removing the panels.
      • Carefully remove the back panel.
      댓글 쓰기
    1. Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 7 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W830 Button Board Replacement, Button Board: 7 단계, 이미지 2개 중 2개
      • Gently release the button board from the clips.
      • Be careful when lifting the button board; the ribbon cable will still be attached.
      댓글 쓰기
    2. Sony Cyber-Shot DSC-W830 Button Board Replacement: 8 단계, 이미지 2개 중 1개 Sony Cyber-Shot DSC-W830 Button Board Replacement: 8 단계, 이미지 2개 중 2개
      • Disconnect the no-fuss ribbon cable by gently pulling it out of the button board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Addyson Salalila
회원 가입일: 09/15/16
316 평판
안내서 2개를 작성함
USF Tampa, Team 17-1, Blackwell Fall 2016 USF Tampa, Team 17-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G1
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 56
전체 시간: 2,172
