주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-P9 Lens Replacement
필요한 것
    1. Sony Cyber-shot DSC-P9 Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide the battery latch down the side of the camera with your hands.
      • The latch will automatically pop open.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Lens Replacement: 2 단계, 이미지 1개 중 1개
      • Unlatch the clip over the battery.
      • The battery will partially pop out.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Lens Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the battery from the camera.
      댓글 쓰기
    1. Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement, Outer Casing: 4 단계, 이미지 2개 중 2개
      • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
      • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Lens Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement: 5 단계, 이미지 2개 중 2개
      • Once the screws are removed, slowly remove the back casing from the rest of the camera.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Lens Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement: 6 단계, 이미지 2개 중 2개
      • Then, pull the front case away from the rest of the camera.
      댓글 쓰기
    4. Sony Cyber-shot DSC-P9 Lens Replacement: 7 단계, 이미지 1개 중 1개
      • After the casing is removed, the camera should look as shown.
      댓글 쓰기
    1. Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 8 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement, Lens: 8 단계, 이미지 2개 중 2개
      • Dislodge the round casing from the lens.
      • Pull it away from the rest of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Lens Replacement: 9 단계, 이미지 1개 중 1개
      • Unscrew the two 4.0mm Phillips #000 screws from the display.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Lens Replacement: 10 단계, 이미지 1개 중 1개
      • Pull the two ribbon cables out of their slots on the back circuit board.
      댓글 쓰기
    4. Sony Cyber-shot DSC-P9 Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the three 4.0mm Phillips #000 screws holding the back panel in place.
      댓글 쓰기
    5. Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-P9 Lens Replacement: 12 단계, 이미지 3개 중 3개
      • Work the back panel out from under the small grey clip.
      • Slide the back panel off of the camera by dislodging it from the remaining clips.
      • Below is a flat, orange cable connecting the lens to the motherboard.
      • Be careful not to bend the back plate during this process.
      댓글 쓰기
    6. Sony Cyber-shot DSC-P9 Lens Replacement: 13 단계, 이미지 1개 중 1개
      • Turn the camera over so that you can see the front of the lens.
      • Two connectors link the lens to the motherboard.
      • Gently bring the lens away from the camera.
      댓글 쓰기
    7. Sony Cyber-shot DSC-P9 Lens Replacement: 14 단계, 이미지 1개 중 1개
      • Using the flat end of the plastic spudger tool, flip up the black tabs on the connectors.
      • Be careful not to exert too much force, as the connectors are delicate.
      댓글 쓰기
    8. Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 3개 중 1개 Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 3개 중 2개 Sony Cyber-shot DSC-P9 Lens Replacement: 15 단계, 이미지 3개 중 3개
      • Gently pull out the cables and move the lens away from the rest of the camera.
      • You should now have two distinct, separate components.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Sean Sayles
회원 가입일: 05/09/12
7 평판
안내서 1개를 작성함
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G25
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 1,969
