주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Cyber-shot DSC-P9 Top Button Replacement
필요한 것
    1. Sony Cyber-shot DSC-P9 Top Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Slide the battery latch down the side of the camera with your hands.
      • The latch will automatically pop open.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Top Button Replacement: 2 단계, 이미지 1개 중 1개
      • Unlatch the clip over the battery.
      • The battery will partially pop out.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Top Button Replacement: 3 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Top Button Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the battery from the camera.
      댓글 쓰기
    1. Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: 4 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Top Button Replacement, Outer Casing: 4 단계, 이미지 2개 중 2개
      • Remove the four 3.0mm Phillips #000 screws on the top of the camera with the phillips screwdriver.
      • Remove the additional four 3.0mm Phillips #000 screws on the bottom of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Top Button Replacement: 5 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Top Button Replacement: 5 단계, 이미지 2개 중 2개
      • Once the screws are removed, slowly remove the back casing from the rest of the camera.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Top Button Replacement: 6 단계, 이미지 2개 중 1개 Sony Cyber-shot DSC-P9 Top Button Replacement: 6 단계, 이미지 2개 중 2개
      • Then, pull the front case away from the rest of the camera.
      댓글 쓰기
    4. Sony Cyber-shot DSC-P9 Top Button Replacement: 7 단계, 이미지 1개 중 1개
      • After the casing is removed, the camera should look as shown.
      댓글 쓰기
    1. Sony Cyber-shot DSC-P9 Top Button Replacement, Top Button: 8 단계, 이미지 1개 중 1개
      • Remove the 3.0mm Phillips #000 screw above the battery door on the side of the camera.
      댓글 쓰기
    2. Sony Cyber-shot DSC-P9 Top Button Replacement: 9 단계, 이미지 1개 중 1개
      • Pull off the pieces of casing located on either side of the top button of the camera.
      • Both of the two pieces should slide off very easily. Do not force them off.
      댓글 쓰기
    3. Sony Cyber-shot DSC-P9 Top Button Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the top button piece. You will need to detach a small blue ribbon cable before the button can be fully removed.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Andrew Forster
회원 가입일: 04/16/12
12 평판
안내서 2개를 작성함
Cal Poly, Team 17-25, Amido Spring 2012 Cal Poly, Team 17-25, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G25
4 회원들
안내서 21개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 31
전체 시간: 1,092
