주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony DSC-RX10M3 Back and Right Panel Replacement
필요한 것
  1. Sony DSC-RX10M3 Back and Right Panel Replacement, Battery Replacement: 1 단계, 이미지 1개 중 1개
    • Turn off the Device by scrolling the tab to "OFF" indicated by the arrow.
    댓글 쓰기
  2. Sony DSC-RX10M3 Back and Right Panel Replacement: 2 단계, 이미지 3개 중 1개 Sony DSC-RX10M3 Back and Right Panel Replacement: 2 단계, 이미지 3개 중 2개 Sony DSC-RX10M3 Back and Right Panel Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the battery located at the bottom of the device.
    댓글 쓰기
  3. Sony DSC-RX10M3 Back and Right Panel Replacement, Back and Right Panel: 3 단계, 이미지 1개 중 1개
    • Remove the twelve 0.7mm Phillips #000 screws from the bottom case.
    댓글 쓰기
  4. Sony DSC-RX10M3 Back and Right Panel Replacement: 4 단계, 이미지 2개 중 1개 Sony DSC-RX10M3 Back and Right Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the two 0.7mm screws that secure the right side of the camera.
    • Remove the two 0.7mm screws that secure the left side of the camera, near the Wi-Fi logo and charging port.
    댓글 쓰기
  5. Sony DSC-RX10M3 Back and Right Panel Replacement: 5 단계, 이미지 2개 중 1개 Sony DSC-RX10M3 Back and Right Panel Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull off the plastic eye guard.
    댓글 쓰기
  6. Sony DSC-RX10M3 Back and Right Panel Replacement: 6 단계, 이미지 2개 중 1개 Sony DSC-RX10M3 Back and Right Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Use a Phillips #000 screwdriver to remove the four 0.4mm screws located under the rubber eye guard.
    • Use a plastic opening tool to detach the back panel of the camera.
    댓글 쓰기
  7. Sony DSC-RX10M3 Back and Right Panel Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • This is a tight spot; make sure you use minimal force when removing the cover.
    • Using tweezers, disconnect the ribbon cable connecting the LCD to the circuit board.
    댓글 쓰기
  8. Sony DSC-RX10M3 Back and Right Panel Replacement: 8 단계, 이미지 1개 중 1개
    • This step is only needed if you wish to remove the right side panel.
    • Use a plastic openeing tool to gently detach the right panel.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Salman Hersi
회원 가입일: 01/14/20
339 평판
안내서 2개를 작성함
York University, Team S4-G4, Woodhouse Winter 2020 York University, Team S4-G4, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S4G4
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 66
전체 시간: 1,932
