주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony DVP-SR200P DVD Drive Replacement
필요한 것
    1. Sony DVP-SR200P DVD Drive Replacement, Top Cover: 1 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Drive Replacement, Top Cover: 1 단계, 이미지 2개 중 2개
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Drive Replacement: 2 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Drive Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the cover away from the front of the DVD player until it is off.
      댓글 쓰기
    1. Sony DVP-SR200P DVD Drive Replacement, Processing Board: 3 단계, 이미지 1개 중 1개
      • Remove the blue tape from the processing board by gently pulling upward.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Drive Replacement: 4 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Drive Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      댓글 쓰기
    3. Sony DVP-SR200P DVD Drive Replacement: 5 단계, 이미지 1개 중 1개
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      댓글 쓰기
    4. Sony DVP-SR200P DVD Drive Replacement: 6 단계, 이미지 1개 중 1개
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      댓글 쓰기
    1. Sony DVP-SR200P DVD Drive Replacement, DVD Drive: 7 단계, 이미지 1개 중 1개
      • Orient the DVD player so the front of the DVD player is opposite of you.
      • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Drive Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Kaitlyn Reilly
회원 가입일: 01/11/13
54 평판
안내서 1개를 작성함
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 회원
CPSU-FORTE-W13S5G17
5 회원들
안내서 54개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 51
전체 시간: 4,598
