주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony DVP-SR200P DVD Reader Replacement
필요한 것
    1. Sony DVP-SR200P DVD Reader Replacement, Top Cover: 1 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Reader Replacement, Top Cover: 1 단계, 이미지 2개 중 2개
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Reader Replacement: 2 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Reader Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the cover away from the front of the DVD player until it is off.
      댓글 쓰기
    1. Sony DVP-SR200P DVD Reader Replacement, Processing Board: 3 단계, 이미지 1개 중 1개
      • Remove the blue tape from the processing board by gently pulling upward.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Reader Replacement: 4 단계, 이미지 2개 중 1개 Sony DVP-SR200P DVD Reader Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      댓글 쓰기
    3. Sony DVP-SR200P DVD Reader Replacement: 5 단계, 이미지 1개 중 1개
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      댓글 쓰기
    4. Sony DVP-SR200P DVD Reader Replacement: 6 단계, 이미지 1개 중 1개
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      댓글 쓰기
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Drive: 7 단계, 이미지 1개 중 1개
      • Orient the DVD player so the front of the DVD player is opposite of you.
      • Remove the two #1 Phillips screws (silver, 3/16") that attach the DVD drive to the bottom of the DVD player.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Reader Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the DVD drive by pulling it backward and upward while ensuring that it is free of any braces.
      댓글 쓰기
    1. Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 3개 중 1개 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 3개 중 2개 Sony DVP-SR200P DVD Reader Replacement, DVD Reader: 9 단계, 이미지 3개 중 3개
      • Flip the DVD drive upside down, to match the orientation of the first picture.
      • Carefully remove the white ribbon cable from the brace holding it in place by sliding it out towards you.
      • Next remove the brace from the DVD drive. Carefully wiggle and pull the brace upward as the white ribbon cable slides out through the brace.
      댓글 쓰기
    2. Sony DVP-SR200P DVD Reader Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the four silver #1 Phillips 3/16''screws to free the DVD reader from the DVD drive.
      댓글 쓰기
    3. Sony DVP-SR200P DVD Reader Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the DVD reader from the DVD drive by pulling it upwards off of the drive.
      • The DVD reader can now be replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jose Coronel
회원 가입일: 01/11/13
84 평판
안내서 1개를 작성함
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 회원
CPSU-FORTE-W13S5G17
5 회원들
안내서 54개를 작성함
1가이드 댓글
Which part help to play games in dvd player
WWE Final Fighters - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 53
전체 시간: 5,601
