주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony DVP-SR200P Processing Board Replacement
필요한 것
    1. Sony DVP-SR200P Processing Board Replacement, Top Cover: 1 단계, 이미지 2개 중 1개 Sony DVP-SR200P Processing Board Replacement, Top Cover: 1 단계, 이미지 2개 중 2개
      • Remove the five #1 Phillips screws (black, 3/16") attaching the cover to the DVD player.
      • One 3/16" screw on the right side of the DVD player.
      • One 3/16" screw on the left side of the DVD player (directly opposite of other screw).
      • Three 3/16" screws on the back of the DVD player.
      댓글 쓰기
    2. Sony DVP-SR200P Processing Board Replacement: 2 단계, 이미지 2개 중 1개 Sony DVP-SR200P Processing Board Replacement: 2 단계, 이미지 2개 중 2개
      • Slide the cover away from the front of the DVD player until it is off.
      댓글 쓰기
    1. Sony DVP-SR200P Processing Board Replacement, Processing Board: 3 단계, 이미지 1개 중 1개
      • Remove the blue tape from the processing board by gently pulling upward.
      댓글 쓰기
    2. Sony DVP-SR200P Processing Board Replacement: 4 단계, 이미지 2개 중 1개 Sony DVP-SR200P Processing Board Replacement: 4 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Use the tweezers to remove the four sets of wires connected to the processing board. Start with the cord located in front of the row of three cords.
      • The wires may be difficult to remove. Wiggling them while lifting them up may help remove them.
      댓글 쓰기
    3. Sony DVP-SR200P Processing Board Replacement: 5 단계, 이미지 1개 중 1개
      • Handle the processing board with care. It is fragile.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the two edge corners of the processing board.
      댓글 쓰기
    4. Sony DVP-SR200P Processing Board Replacement: 6 단계, 이미지 1개 중 1개
      • Orient the DVD player so that you are facing the video and audio jacks.
      • Unscrew the two #1 Phillips screws (silver, 3/16") located on the outside of the DVD player
      • The processing board is now free to be removed and replaced.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Brian Hua
회원 가입일: 01/11/13
80 평판
안내서 3개를 작성함
Cal Poly, Team 5-17, Forte Winter 2013 Cal Poly, Team 5-17, Forte Winter 2013 회원
CPSU-FORTE-W13S5G17
5 회원들
안내서 54개를 작성함
3가이드 댓글
I have Sony DVD player dvp at510p. After switching it runs then automatic Power go down while running it's process ic get hotter and hotter what's the right solutions plz help me
Dhiraj Vasave - 답글 공유
SO my DVD player run 5to 6 minutes then automatic stop all power goes to less
My DVD player not run but power on Bluetooth not connect
Sony - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 58
전체 시간: 2,416
