주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson W200i Back Case Replacement
필요한 것
  1. Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2개 중 1개 Sony Ericsson W200i Back Case Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2개 중 2개
    • Slide the battery cover up and off the phone.
    댓글 쓰기
  2. Sony Ericsson W200i Back Case Replacement: 2 단계, 이미지 2개 중 1개 Sony Ericsson W200i Back Case Replacement: 2 단계, 이미지 2개 중 2개
    • Pop the battery out of its slot by lifting it up.
    댓글 쓰기
  3. Sony Ericsson W200i Back Case Replacement, Front Case: 3 단계, 이미지 3개 중 1개 Sony Ericsson W200i Back Case Replacement, Front Case: 3 단계, 이미지 3개 중 2개 Sony Ericsson W200i Back Case Replacement, Front Case: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in between the front case and the back case.
    • Apply downward pressure to make the case lift upwards, thus popping the front case off.
    • Use caution when removing the front case. It may seem stuck but just ease it out.
    댓글 쓰기
  4. Sony Ericsson W200i Back Case Replacement, Core: 4 단계, 이미지 2개 중 1개 Sony Ericsson W200i Back Case Replacement, Core: 4 단계, 이미지 2개 중 2개
    • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
    • Note that the top 2 screws are silver and the bottom 2 screws are black.
    댓글 쓰기
  5. Sony Ericsson W200i Back Case Replacement: 5 단계, 이미지 3개 중 1개 Sony Ericsson W200i Back Case Replacement: 5 단계, 이미지 3개 중 2개 Sony Ericsson W200i Back Case Replacement: 5 단계, 이미지 3개 중 3개
    • There is a black tab in the top left corner holding the core in place.
    • Remove the core by pulling straight up to prevent breaking the tab.
    댓글 쓰기
  6. Sony Ericsson W200i Back Case Replacement, Back Case: 6 단계, 이미지 3개 중 1개 Sony Ericsson W200i Back Case Replacement, Back Case: 6 단계, 이미지 3개 중 2개 Sony Ericsson W200i Back Case Replacement, Back Case: 6 단계, 이미지 3개 중 3개
    • Pull back on the indicated tab of the white plastic cover to unhook it from the top of the phone.
    • Using the plastic opening tool, undo the indicated clip on the bottom of the white plastic cover.
    • Remove the white plastic cover.
    댓글 쓰기
결론
To reassemble your device, put removed pieces into the new back casing, then follow the steps in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Emily Prescott
회원 가입일: 01/10/11
531 평판
안내서 4개를 작성함
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 회원
CPSU-FORTE-W11S14G10
5 회원들
안내서 32개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 10
지난 30일: 40
전체 시간: 4,115
