주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson W200i LCD Screen Replacement
필요한 것
    1. Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2개 중 1개 Sony Ericsson W200i LCD Screen Replacement, Disassembling Sony Ericsson W200i Battery: 1 단계, 이미지 2개 중 2개
      • Slide the battery cover up and off the phone.
      댓글 쓰기
    2. Sony Ericsson W200i LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Sony Ericsson W200i LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Pop the battery out of its slot by lifting it up.
      댓글 쓰기
    1. Sony Ericsson W200i LCD Screen Replacement, Front Case: 3 단계, 이미지 3개 중 1개 Sony Ericsson W200i LCD Screen Replacement, Front Case: 3 단계, 이미지 3개 중 2개 Sony Ericsson W200i LCD Screen Replacement, Front Case: 3 단계, 이미지 3개 중 3개
      • Insert the plastic opening tool in between the front case and the back case.
      • Apply downward pressure to make the case lift upwards, thus popping the front case off.
      • Use caution when removing the front case. It may seem stuck but just ease it out.
      댓글 쓰기
    1. Sony Ericsson W200i LCD Screen Replacement, Core: 4 단계, 이미지 2개 중 1개 Sony Ericsson W200i LCD Screen Replacement, Core: 4 단계, 이미지 2개 중 2개
      • Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
      • Note that the top 2 screws are silver and the bottom 2 screws are black.
      댓글 쓰기
    2. Sony Ericsson W200i LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Sony Ericsson W200i LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Sony Ericsson W200i LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
      • There is a black tab in the top left corner holding the core in place.
      • Remove the core by pulling straight up to prevent breaking the tab.
      댓글 쓰기
    1. Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 1개 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 2개 Sony Ericsson W200i LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 3개
      • Undo the metal clip on each side of the core using the plastic opening tool.
      • Do not bend clips past 2mm or they could break.
      댓글 쓰기
    2. Sony Ericsson W200i LCD Screen Replacement: 7 단계, 이미지 3개 중 1개 Sony Ericsson W200i LCD Screen Replacement: 7 단계, 이미지 3개 중 2개 Sony Ericsson W200i LCD Screen Replacement: 7 단계, 이미지 3개 중 3개
      • Gently pull the white keyboard and charging port away from the motherboard and off the phone.
      댓글 쓰기
    3. Sony Ericsson W200i LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 Sony Ericsson W200i LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 Sony Ericsson W200i LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Undo the grey clip that holds the LCD ribbon in place by loosening one side of the clip with the plastic opening tool, then gently separate the other side of the clip from the holder.
      • The copper end of the ribbon should slide out of the housing as you pull the LCD up and away from the motherboard.
      • Using too much force may bend the copper ribbon.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Austin Cade
회원 가입일: 01/11/11
198 평판
안내서 1개를 작성함
Cal Poly, Team 14-10, Forte Winter 2011 Cal Poly, Team 14-10, Forte Winter 2011 회원
CPSU-FORTE-W11S14G10
5 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 50
전체 시간: 8,654
