주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson W580i SIM Card Replacement
필요한 것
    1. Sony Ericsson W580i SIM Card Replacement, Battery: 1 단계, 이미지 3개 중 1개 Sony Ericsson W580i SIM Card Replacement, Battery: 1 단계, 이미지 3개 중 2개 Sony Ericsson W580i SIM Card Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
      • The panel will slide down about 2mm.
      • Lift the panel away from the phone.
      댓글 쓰기
    2. Sony Ericsson W580i SIM Card Replacement: 2 단계, 이미지 1개 중 1개
      • Lift the battery out from the bottom edge.
      댓글 쓰기
    1. Sony Ericsson W580i SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 Sony Ericsson W580i SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 Sony Ericsson W580i SIM Card Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
      • Locate the SIM card slot.
      • Use a spudger to release the SIM card by pushing it in slightly until you feel a "click."
      • Release pressure from the SIM card. The SIM card will pop out about 5mm.
      댓글 쓰기
    2. Sony Ericsson W580i SIM Card Replacement: 4 단계, 이미지 2개 중 1개 Sony Ericsson W580i SIM Card Replacement: 4 단계, 이미지 2개 중 2개
      • Slide the SIM card down out of the slot.
      • Remove the SIM card from the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Diego
회원 가입일: 10/09/11
397 평판
안내서 4개를 작성함
Cal Poly, Team 5-31, Amido Fall 2011 Cal Poly, Team 5-31, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G31
4 회원들
안내서 24개를 작성함
2가이드 댓글
where do you get thease parts
Joy Martin - 답글 공유
helllo i have an extremely big issue, i've been driving myself CRAZY for almost 6 years trying to figure out how to enter the sim card, i own one but i do not understand why its not fitting in, it's literally the exact same diameter as far as im concerned, hell i even tried it on another old phone AND IT DID FIT, i do not exactly have enough help online or presence to help me or guide me so could we email each other or something??? i really need this :(
Crossgrover Tv - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 22
지난 30일: 80
전체 시간: 13,740
