주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson W810I Camera Replacement
필요한 것
  1. Sony Ericsson W810I Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
    댓글 쓰기
  2. Sony Ericsson W810I Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
    댓글 쓰기
  3. Sony Ericsson W810I Camera Replacement: 3 단계, 이미지 2개 중 1개 Sony Ericsson W810I Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
    댓글 쓰기
  4. Sony Ericsson W810I Camera Replacement, Case: 4 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement, Case: 4 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement, Case: 4 단계, 이미지 3개 중 3개
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
    댓글 쓰기
  5. Sony Ericsson W810I Camera Replacement: 5 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 5 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 5 단계, 이미지 3개 중 3개
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
    댓글 쓰기
  6. Sony Ericsson W810I Camera Replacement: 6 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 6 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
    댓글 쓰기
  7. Sony Ericsson W810I Camera Replacement: 7 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 7 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 7 단계, 이미지 3개 중 3개
    • Run the plastic opening tool upwards along that side, removing the housing.
    댓글 쓰기
  8. Sony Ericsson W810I Camera Replacement, Key Pad: 8 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement, Key Pad: 8 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement, Key Pad: 8 단계, 이미지 3개 중 3개
    • Peel the rubber keys away from their backing. Do not slide them off.
    • Set them aside.
    댓글 쓰기
  9. Sony Ericsson W810I Camera Replacement: 9 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 9 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool under the left side of the keypad backing and start to lift.
    • Lift slowly, as you can damage the ribbon cable underneath if you pull the keypad backing away too forcefully.
    댓글 쓰기
  10. Sony Ericsson W810I Camera Replacement: 10 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 10 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 10 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool under the ribbon cable attachment and give a small push upwards to dislodge it.
    댓글 쓰기
  11. Sony Ericsson W810I Camera Replacement, LCD Screen: 11 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement, LCD Screen: 11 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement, LCD Screen: 11 단계, 이미지 3개 중 3개
    • Remove the indicated 6.35mm screws with a Torx T6 screwdriver.
    댓글 쓰기
  12. Sony Ericsson W810I Camera Replacement: 12 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 12 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Pull LCD screen gently out and the to side. Do not attempt to pull it completely away from the board below it.
    • Push up on the underside of the cable at the point of attachment with a plastic opening tool to detach it. The screen can now be separated.
    댓글 쓰기
  13. Sony Ericsson W810I Camera Replacement, Motherboard: 13 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement, Motherboard: 13 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement, Motherboard: 13 단계, 이미지 3개 중 3개
    • Using a plastic opening device, push against the underside of the brown portion of the the ribbon cable to unplug it.
    댓글 쓰기
  14. Sony Ericsson W810I Camera Replacement: 14 단계, 이미지 1개 중 1개
    • Using a plastic opening device, separate the top of the motherboard from the rest of the plastic casing.
    댓글 쓰기
  15. Sony Ericsson W810I Camera Replacement: 15 단계, 이미지 3개 중 1개 Sony Ericsson W810I Camera Replacement: 15 단계, 이미지 3개 중 2개 Sony Ericsson W810I Camera Replacement: 15 단계, 이미지 3개 중 3개
    • Pull forwards slightly on the motherboard so that it starts to fall out of the casing.
    • Thread the ribbon cable through the hole in the motherboard so that it does not become caught.
    댓글 쓰기
  16. Sony Ericsson W810I Camera Replacement, Camera: 16 단계, 이미지 2개 중 1개 Sony Ericsson W810I Camera Replacement, Camera: 16 단계, 이미지 2개 중 2개
    • Push against the underside of the ribbon cable at the point of attachment with a plastic opening tool until it detaches.
    댓글 쓰기
  17. Sony Ericsson W810I Camera Replacement: 17 단계, 이미지 1개 중 1개
    • Pull the ribbon cable to the side.
    댓글 쓰기
  18. Sony Ericsson W810I Camera Replacement: 18 단계, 이미지 2개 중 1개 Sony Ericsson W810I Camera Replacement: 18 단계, 이미지 2개 중 2개
    • Flip over the phone so that the side previously facing you is now facing away.
    • Push gently on the camera module from the side currently facing you. The module should fall away from the plastic mount.
    • Insert the new camera module into the now empty space.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Lucy Bowen
회원 가입일: 09/01/11
473 평판
안내서 7개를 작성함
Cuesta, Team 1-7, Zipperian Fall 2011 Cuesta, Team 1-7, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G7
1 회원
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 43
전체 시간: 4,370
