주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson W810I Case Replacement
필요한 것
  1. Sony Ericsson W810I Case Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Place your Sony Ericsson W810I screen side down with the battery cover facing up as shown.
    댓글 쓰기
  2. Sony Ericsson W810I Case Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the battery cover by applying downward pressure on the Singular Symbol and then shifting the pressure towards the bottom edge of the phone.
    댓글 쓰기
  3. Sony Ericsson W810I Case Replacement: 3 단계, 이미지 2개 중 1개 Sony Ericsson W810I Case Replacement: 3 단계, 이미지 2개 중 2개
    • Lift the bottom of the battery away from the phone with your thumb and rotate until the opening in the bottom of the case is oriented downward. The battery should slide out.
    댓글 쓰기
  4. Sony Ericsson W810I Case Replacement, Case: 4 단계, 이미지 3개 중 1개 Sony Ericsson W810I Case Replacement, Case: 4 단계, 이미지 3개 중 2개 Sony Ericsson W810I Case Replacement, Case: 4 단계, 이미지 3개 중 3개
    • Remove the two 3.9mm screws with a Phillips size #00 screwdriver.
    • Remove the two 6.35mm screws with a Torx T6 screwdriver.
    댓글 쓰기
  5. Sony Ericsson W810I Case Replacement: 5 단계, 이미지 3개 중 1개 Sony Ericsson W810I Case Replacement: 5 단계, 이미지 3개 중 2개 Sony Ericsson W810I Case Replacement: 5 단계, 이미지 3개 중 3개
    • Run a plastic opening tool along the edge of the back casing while prying it apart to remove it.
    댓글 쓰기
  6. Sony Ericsson W810I Case Replacement: 6 단계, 이미지 3개 중 1개 Sony Ericsson W810I Case Replacement: 6 단계, 이미지 3개 중 2개 Sony Ericsson W810I Case Replacement: 6 단계, 이미지 3개 중 3개
    • Turn the phone over and open the memory stick compartment.
    • Stick a plastic opening tools into the opening and twist it to gain some leverage. This should begin separating the front casing from the interior plastic support frame.
    댓글 쓰기
  7. Sony Ericsson W810I Case Replacement: 7 단계, 이미지 3개 중 1개 Sony Ericsson W810I Case Replacement: 7 단계, 이미지 3개 중 2개 Sony Ericsson W810I Case Replacement: 7 단계, 이미지 3개 중 3개
    • Run the plastic opening tool upwards along that side, removing the housing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Lucy Bowen
회원 가입일: 09/01/11
473 평판
안내서 7개를 작성함
Cuesta, Team 1-7, Zipperian Fall 2011 Cuesta, Team 1-7, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G7
1 회원
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 49
전체 시간: 5,162
