주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson Xperia Play Digitizer Replacement
필요한 것
  1. Sony Ericsson Xperia Play Digitizer Replacement, Digitizer: 1 단계, 이미지 1개 중 1개
    • Remove the 6 silver torx screws marked in red
    댓글 쓰기
  2. Sony Ericsson Xperia Play Digitizer Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the 7 black torx screws marked in yellow.
    댓글 쓰기
  3. Sony Ericsson Xperia Play Digitizer Replacement: 3 단계, 이미지 1개 중 1개
    • Using a plastic prying tool, go around the outside of the phone releasing the plastic clips.
    댓글 쓰기
  4. Sony Ericsson Xperia Play Digitizer Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the plastic housing revealing the motherboard
    • Remove the two Phillips screws.
    댓글 쓰기
  5. Sony Ericsson Xperia Play Digitizer Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the headphone jack by carefully moving the dark plastic clip on the connector to 90 degrees
    댓글 쓰기
  6. Sony Ericsson Xperia Play Digitizer Replacement: 6 단계, 이미지 1개 중 1개
    • Slide the phone to the open position
    댓글 쓰기
  7. Sony Ericsson Xperia Play Digitizer Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the display connector marked in orange using a plastic spudger to pry it upwards
    • Remove the connector for the front buttons by prising the retaining clip to 90 degrees
    댓글 쓰기
  8. Sony Ericsson Xperia Play Digitizer Replacement: 8 단계, 이미지 1개 중 1개
    • Remove motherboard
    댓글 쓰기
  9. Sony Ericsson Xperia Play Digitizer Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the buttons from the phone
    댓글 쓰기
  10. Sony Ericsson Xperia Play Digitizer Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the three Phillips screws.
    댓글 쓰기
  11. Sony Ericsson Xperia Play Digitizer Replacement: 11 단계, 이미지 1개 중 1개
    • Slide the metal frame across revealing the last screw . Make sure to keep the plastic cover after removing the screw
    • Disconnect the digitizer cable
    댓글 쓰기
  12. Sony Ericsson Xperia Play Digitizer Replacement: 12 단계, 이미지 1개 중 1개
    • Insert a plastic spudger around the edge of the frame and take the lcd assembely from the glass
    • Using a heat gun heat around the edges of the glass to soften the glue, and use your prying tool between the glass and the frame to take the glass off.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Kris James
회원 가입일: 01/27/12
684 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 65
전체 시간: 32,237
