주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson Xperia X10 Camera Replacement
필요한 것
    1. Sony Ericsson Xperia X10 Camera Replacement, Camera: 1 단계, 이미지 2개 중 1개 Sony Ericsson Xperia X10 Camera Replacement, Camera: 1 단계, 이미지 2개 중 2개
      • To access the internal components, such as the camera, we need to flip the phone with the screen facing down. Once this is done remove the battery.
      댓글 쓰기
    2. Sony Ericsson Xperia X10 Camera Replacement: 2 단계, 이미지 1개 중 1개
      • Remove eight 5mm screws as shown in the image. Use a T-6 bit.
      댓글 쓰기
    3. Sony Ericsson Xperia X10 Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Using a case opener, start on the bottom right side of the phone and undo clips located at the interior sides. Repeat this step for the left side.
      댓글 쓰기
    4. Sony Ericsson Xperia X10 Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Once the clips are undone the back casing should dislocate and reveal the internal components of the phone. Camera location is identified on the image.
      댓글 쓰기
    5. Sony Ericsson Xperia X10 Camera Replacement: 5 단계, 이미지 3개 중 1개 Sony Ericsson Xperia X10 Camera Replacement: 5 단계, 이미지 3개 중 2개 Sony Ericsson Xperia X10 Camera Replacement: 5 단계, 이미지 3개 중 3개
      • To remove the internal case surrounding the camera, apply pressure on the left side of internal casing and using a flat head screw driver unlatch both clips on the right side of casing. Once lifted detach ribbon cable with flat head screwdriver.
      댓글 쓰기
    6. Sony Ericsson Xperia X10 Camera Replacement: 6 단계, 이미지 2개 중 1개 Sony Ericsson Xperia X10 Camera Replacement: 6 단계, 이미지 2개 중 2개
      • Once the interior casing is removed, dislocate the hardware by unlatching clip at shown location.
      댓글 쓰기
    7. Sony Ericsson Xperia X10 Camera Replacement: 7 단계, 이미지 1개 중 1개
      • To remove damaged camera flip hardware so the lens of the camera is facing downwards and remove ribbon cable connecting camera to hardware.
      댓글 쓰기
    8. Sony Ericsson Xperia X10 Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Once camera is removed, insert new functional camera part and reassemble
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Bryan
회원 가입일: 11/03/13
410 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 32
전체 시간: 1,117
