주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Ericsson z300 Screens Replacement
필요한 것
    1. Sony Ericsson z300 Screens Replacement, Back Phone Cover: 1 단계, 이미지 1개 중 1개
      • To remove the back cover, use your thumb to press down on the center of case and slide it off.
      댓글 쓰기
    1. Sony Ericsson z300 Screens Replacement, Battery: 2 단계, 이미지 1개 중 1개
      • Using a fingernail lift the battery out of the phone.
      댓글 쓰기
    1. Sony Ericsson z300 Screens Replacement, Front Phone Cover: 3 단계, 이미지 1개 중 1개
      • To remove the front cover, lift up the case with a fingernail in the small slot as shown.
      댓글 쓰기
    1. Sony Ericsson z300 Screens Replacement, Front Dark Grey Case: 4 단계, 이미지 1개 중 1개
      • To remove the front grey case, remove the two screws shown with a T5 Torx Screwdriver.
      댓글 쓰기
    2. Sony Ericsson z300 Screens Replacement: 5 단계, 이미지 1개 중 1개
      • Pry up the dark grey case with your fingernail until all four snaps around the top are loose.
      댓글 쓰기
    3. Sony Ericsson z300 Screens Replacement: 6 단계, 이미지 1개 중 1개
      • Lift up towards the bottom and slide the case off.
      댓글 쓰기
    1. Sony Ericsson z300 Screens Replacement, Screens: 7 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to lift the black tape off of the ribbon cable connector.
      댓글 쓰기
    2. Sony Ericsson z300 Screens Replacement: 8 단계, 이미지 1개 중 1개
      • Lift the ribbon cable connector lock using a plastic opening tool.
      댓글 쓰기
    3. Sony Ericsson z300 Screens Replacement: 9 단계, 이미지 2개 중 1개 Sony Ericsson z300 Screens Replacement: 9 단계, 이미지 2개 중 2개
      • Slide the black ribbon cable tray out with a plastic opening tool.
      • Shown in the second picture is the try already slid out.
      댓글 쓰기
    4. Sony Ericsson z300 Screens Replacement: 10 단계, 이미지 2개 중 1개 Sony Ericsson z300 Screens Replacement: 10 단계, 이미지 2개 중 2개
      • Slide the ribbon cable out of the connector.
      • Shown in the second picture is the cable already out.
      댓글 쓰기
    5. Sony Ericsson z300 Screens Replacement: 11 단계, 이미지 1개 중 1개
      • Use a plastic opening tool to lift up on the screen board and release the clips holding it in place.
      • Lift the entire board out of the phone to remove both screens.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Alex Serventi
회원 가입일: 10/07/10
65 평판
안내서 13개를 작성함
Cal Poly, Team 5-15, Maness Fall 2010 Cal Poly, Team 5-15, Maness Fall 2010 회원
CPSU-MANESS-F10S5G15
4 회원들
안내서 91개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 1,662
