주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony ICF-C1T Tuner Dial Replacement
필요한 것
    1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: 1 단계, 이미지 1개 중 1개
      • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
      • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
      댓글 쓰기
    2. Sony ICF-C1T Tuner Dial Replacement: 2 단계, 이미지 1개 중 1개
      • Use the opening tool to pry apart the edges of the top and side portions of the device.
      댓글 쓰기
    3. Sony ICF-C1T Tuner Dial Replacement: 3 단계, 이미지 2개 중 1개 Sony ICF-C1T Tuner Dial Replacement: 3 단계, 이미지 2개 중 2개
      • Separate the device by gently pulling up on the top portion.
      • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
      댓글 쓰기
    4. Sony ICF-C1T Tuner Dial Replacement: 4 단계, 이미지 2개 중 1개 Sony ICF-C1T Tuner Dial Replacement: 4 단계, 이미지 2개 중 2개
      • To remove the motherboard, gently pull apart the sides of the device.
      • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
      • Be careful of sharp pieces on the motherboard.
      • Having help for this step might make things quicker and easier.
      댓글 쓰기
    5. Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 3개 중 1개 Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 3개 중 2개 Sony ICF-C1T Tuner Dial Replacement: 5 단계, 이미지 3개 중 3개
      • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
5다른 기여자 명과 함께
Megan
회원 가입일: 01/30/15
275 평판
안내서 2개를 작성함
1가이드 댓글
Thanks, this was not fun but the guide helped.
Campbell Kerr - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 43
전체 시간: 2,501
