주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony ICF-C1T Volume Dial Replacement
필요한 것
  1. Sony ICF-C1T Volume Dial Replacement, Volume Dial: 1 단계, 이미지 1개 중 1개
    • Remove the 4 (14mm) screws from the underside of the device using the Philips #0 Screwdriver.
    • Before beginning this step, make sure the clock is unplugged and the batteries have been removed.
    댓글 쓰기
  2. Sony ICF-C1T Volume Dial Replacement: 2 단계, 이미지 1개 중 1개
    • Pry apart the edge of the top and side portions of the device using a flat-headed tool (i.e. flathead screwdriver, card, etc)
    • It is recommended to use the iFixit Opening Tools for optimal removal.
    댓글 쓰기
  3. Sony ICF-C1T Volume Dial Replacement: 3 단계, 이미지 2개 중 1개 Sony ICF-C1T Volume Dial Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully separate the device by gently pulling up on the top of the clock/radio.
    • Use caution when pulling the top of the clock; the clock display is located directly behind the faceplate and still connected by multiple wires.
    댓글 쓰기
  4. Sony ICF-C1T Volume Dial Replacement: 4 단계, 이미지 2개 중 1개 Sony ICF-C1T Volume Dial Replacement: 4 단계, 이미지 2개 중 2개
    • To remove the motherboard, gently pull apart the sides of the device.
    • Do not pull hard on the motherboard, as it is still connected by multiple wires inside the device.
    • Be careful of sharp pieces.
    • It would be helpful, although not necessary, to have someone helping out with this step.
    댓글 쓰기
  5. Sony ICF-C1T Volume Dial Replacement: 5 단계, 이미지 2개 중 1개 Sony ICF-C1T Volume Dial Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the volume dial by pulling it off the motherboard. This can take a little force to remove.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
amber woolery
회원 가입일: 01/30/15
307 평판
안내서 2개를 작성함
1가이드 댓글
thanks for the great instructions. a few notes: it seems the “edit” comments were all left in above (“no edits necessary” and the stuff about highlighting parts of it). after step 3, there wasn’t instructions about removing the two screws from the motherboard, before step 4.
J Kwan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 30
전체 시간: 1,783
