주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony M-430 Microcassette-Corder Back Cover Replacement
필요한 것
    1. Sony M-430 Microcassette-Corder Back Cover Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Find the arrow on the battery cover on the back of the device.
      • While pressing down on the arrow, slide the cover towards the bottom of the recorder until it clicks.
      댓글 쓰기
    2. Sony M-430 Microcassette-Corder Back Cover Replacement: 2 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Back Cover Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the cover and remove the batteries.
      댓글 쓰기
    1. Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Back Cover Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
      • Remove the battery cover by first tilting it so it is at a right angle with the rest of the device.
      • Next, twist it to the side as shown in the second picture. The lid should simply snap off.
      • Potential for device damage: be careful not to apply too much force, as the lid may break.
      댓글 쓰기
    2. Sony M-430 Microcassette-Corder Back Cover Replacement: 4 단계, 이미지 2개 중 1개 Sony M-430 Microcassette-Corder Back Cover Replacement: 4 단계, 이미지 2개 중 2개
      • Use a #00 Phillips head screwdriver to remove the four (1.7x16 mm) screws from the back case.
      • Next, use the same screwdriver to unscrew the (1.7X5 mm) screw, which is located inside the battery compartment.
      댓글 쓰기
    3. Sony M-430 Microcassette-Corder Back Cover Replacement: 5 단계, 이미지 1개 중 1개
      • Use a spudger to push in the two tabs located on the bottom of the device.
      • It works best to push the tabs at an upward angle (towards the top of the battery compartment). It may take a decent amount of force in order to push in the tabs.
      댓글 쓰기
    4. Sony M-430 Microcassette-Corder Back Cover Replacement: 6 단계, 이미지 1개 중 1개
      • With a firm grip on the larger half, remove the back cover by lifting first on the battery area.
      • The back cover should lift cleanly off.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Matt Teare
회원 가입일: 01/20/12
35 평판
안내서 3개를 작성함
Cal Poly, Team 10-34, Amido Winter 2012 Cal Poly, Team 10-34, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G34
4 회원들
안내서 28개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 41
전체 시간: 2,699
