주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony NEX-7 Lens Mount Replacement
필요한 것
  1. Sony NEX-7 Lens Mount Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony NEX-7 Lens Mount Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
    댓글 쓰기
  2. Sony NEX-7 Lens Mount Replacement: 2 단계, 이미지 1개 중 1개
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
    댓글 쓰기
  3. Sony NEX-7 Lens Mount Replacement: 3 단계, 이미지 1개 중 1개
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
    댓글 쓰기
  4. Sony NEX-7 Lens Mount Replacement, SD card: 4 단계, 이미지 1개 중 1개
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
    댓글 쓰기
  5. Sony NEX-7 Lens Mount Replacement, Lens: 5 단계, 이미지 2개 중 1개 Sony NEX-7 Lens Mount Replacement, Lens: 5 단계, 이미지 2개 중 2개
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
    댓글 쓰기
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: 6 단계, 이미지 1개 중 1개
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
    댓글 쓰기
  7. Sony NEX-7 Lens Mount Replacement: 7 단계, 이미지 1개 중 1개
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
    댓글 쓰기
  8. Sony NEX-7 Lens Mount Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the two newly visible #00 screws within the metal ring.
    댓글 쓰기
  9. Sony NEX-7 Lens Mount Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the final metal ring from the mount.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jay Miley
회원 가입일: 04/22/14
5,453 평판
안내서 13개를 작성함
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G55
4 회원들
안내서 46개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 37
전체 시간: 3,020
