주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony NEX-7 SD card Replacement
    1. Sony NEX-7 SD card Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony NEX-7 SD card Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
      • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
      댓글 쓰기
    2. Sony NEX-7 SD card Replacement: 2 단계, 이미지 1개 중 1개
      • Flip the camera over such that the power switch points down.
      • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
      댓글 쓰기
    3. Sony NEX-7 SD card Replacement: 3 단계, 이미지 1개 중 1개
      • With the battery door open, push the blue lever in the battery compartment to release the battery.
      댓글 쓰기
    1. Sony NEX-7 SD card Replacement, SD card: 4 단계, 이미지 1개 중 1개
      • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
      • Pull the card out with your fingers.
      댓글 쓰기
결론
To replace the SD card, press the card into the slot until it clicks. It will stay on its own. If it doesn't go in all the way, make sure the gold contacts are down and towards the battery door.
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jay Miley
회원 가입일: 04/22/14
5,462 평판
안내서 13개를 작성함
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 회원
CPSU-AMIDO-S14S10G55
4 회원들
안내서 69개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 58
전체 시간: 2,635
