주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PS-LX300USB Needle Replacement
필요한 것
  1. Sony PS-LX300USB  Needle Replacement, Needle: 1 단계, 이미지 3개 중 1개 Sony PS-LX300USB  Needle Replacement, Needle: 1 단계, 이미지 3개 중 2개 Sony PS-LX300USB  Needle Replacement, Needle: 1 단계, 이미지 3개 중 3개
    • Flip the needle cover down.
    • Grasp the needle cartridge between two fingers.
    • Pull the cartridge down and towards you to remove it.
    댓글 쓰기
  2. Sony PS-LX300USB  Needle Replacement: 2 단계, 이미지 3개 중 1개 Sony PS-LX300USB  Needle Replacement: 2 단계, 이미지 3개 중 2개 Sony PS-LX300USB  Needle Replacement: 2 단계, 이미지 3개 중 3개
    • Angle the cartridge diagonally inside the tone arm.
    • Push up and into the tone arm until you hear a click.
    댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Christopher Slaughter
회원 가입일: 09/27/17
401 평판
안내서 2개를 작성함
Cal Poly, Team S8-G3, Banghart Fall 2017 Cal Poly, Team S8-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G3
5 회원들
안내서 5개를 작성함
5가이드 댓글
do you ship to philippines please email me jabez091715@gmail.com
willmermejarito - 답글 공유
Hei, i need a needle , can you send it to my country Bulgaria. Please e-mail me if you have it, anatolt@yahoo.com Thank you. A
anatolt - 답글 공유
So, my needle wore down from the arm having bumped off the rest and who even knows how long the table was turning! My question is, is it possible to add a tone arm lock? I swore mine had one but, apparently, it does not. I have a Sony ps-lx300usb. It’s so odd, cuz there’s nothing that suggests anything broke off but I distinctly remember a lock! Any guidance would be great!
Cathy johnson - 답글 공유
Did you order a needle from the link on this website? Were you satisfied? I am in the same boat you are. In future I won't be leaving the turntable without an lp on it.
C Audley - 답글 공유
I tried removing the needle and have pulled the metal part out with it, now it doesn't play correctly. Any idea how to source the complete arm / needle unit?
Alex Grover - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 39
지난 30일: 212
전체 시간: 33,921
