주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PS-LX300USB Drive Belt Replacement
필요한 것
    1. Sony PS-LX300USB Drive Belt Replacement, Drive Belt: 1 단계, 이미지 2개 중 1개 Sony PS-LX300USB Drive Belt Replacement, Drive Belt: 1 단계, 이미지 2개 중 2개
      • Lift the rubber mat, and put it to the side. It should be easy to remove, because it simply rests on a metal platter without anything securing it down.
      댓글 쓰기
    2. Sony PS-LX300USB Drive Belt Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the platter so that the motor pulley can be seen through one of the two outer holes in the platter.
      • If the drive belt is hooked around the motor pulley, unhook it.
      • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
      댓글 쓰기
    3. Sony PS-LX300USB Drive Belt Replacement: 3 단계, 이미지 1개 중 1개
      • Grasping the platter by its two inner holes, lift it upwards.
      • Removing the platter may take a small amount of force. If the pulley is unhooked and the tone arm is safely to the side, don’t fear using a small amount of force in lifting the platter.
      • If you haven’t yet unhooked the drive belt, the motor pulley and the belt could sustain damage.
      댓글 쓰기
    4. Sony PS-LX300USB Drive Belt Replacement: 4 단계, 이미지 2개 중 1개 Sony PS-LX300USB Drive Belt Replacement: 4 단계, 이미지 2개 중 2개
      • Peel the drive belt from the inner ridge of the metal platter and put it to the side.
      • Sometimes, the drive belt can fall off the platter during deconstruction. If this is the case, simply take it out of the device wherever it is.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 19명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Michelle Jakab
회원 가입일: 09/27/17
633 평판
안내서 1개를 작성함
Cal Poly, Team S8-G3, Banghart Fall 2017 Cal Poly, Team S8-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S8G3
5 회원들
안내서 30개를 작성함
3가이드 댓글
Thank you for posting!
Jeanine Haven - 답글 공유
Thank you for posting this! My belt slipped and I could not figure this out thanks to you I saw how simple a process the repair. Many times thank you
Thank you for this post. I freaked out when belt became detached. I had moved turntable several times to resolve a connection issue and OOPS! Very concise instructions with clear pictures. Awesome!!
Eric Doner - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 30
지난 30일: 188
전체 시간: 20,977
