주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PlayStation Camera Microphone Array Replacement
필요한 것
  1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: 1 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement, Microphone Array: 1 단계, 이미지 2개 중 2개
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    댓글 쓰기
  2. Sony PlayStation Camera Microphone Array Replacement: 2 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 2 단계, 이미지 2개 중 2개
    • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    댓글 쓰기
  3. Sony PlayStation Camera Microphone Array Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the cap holding the cable grommet in place.
    댓글 쓰기
  4. Sony PlayStation Camera Microphone Array Replacement: 4 단계, 이미지 1개 중 1개
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    댓글 쓰기
  5. Sony PlayStation Camera Microphone Array Replacement: 5 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 5 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    댓글 쓰기
  6. Sony PlayStation Camera Microphone Array Replacement: 6 단계, 이미지 1개 중 1개
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    댓글 쓰기
  7. Sony PlayStation Camera Microphone Array Replacement: 7 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 7 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    댓글 쓰기
  8. Sony PlayStation Camera Microphone Array Replacement: 8 단계, 이미지 3개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 8 단계, 이미지 3개 중 2개 Sony PlayStation Camera Microphone Array Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    댓글 쓰기
  9. Sony PlayStation Camera Microphone Array Replacement: 9 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 9 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    댓글 쓰기
  10. Sony PlayStation Camera Microphone Array Replacement: 10 단계, 이미지 2개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 10 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    댓글 쓰기
  11. Sony PlayStation Camera Microphone Array Replacement: 11 단계, 이미지 3개 중 1개 Sony PlayStation Camera Microphone Array Replacement: 11 단계, 이미지 3개 중 2개 Sony PlayStation Camera Microphone Array Replacement: 11 단계, 이미지 3개 중 3개
    • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
    • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joshua Gates
회원 가입일: 02/15/17
268 평판
안내서 2개를 작성함
USF Tampa, Team 5-5, Passmore Spring 2017 USF Tampa, Team 5-5, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G5
3 회원들
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 64
전체 시간: 7,801
