주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony PlayStation Camera Motherboard Replacement
필요한 것
  1. Sony PlayStation Camera Motherboard Replacement, Motherboard/Camera(s): 1 단계, 이미지 2개 중 1개 Sony PlayStation Camera Motherboard Replacement, Motherboard/Camera(s): 1 단계, 이미지 2개 중 2개
    • Separate the camera from the camera stand to gain access to the bottom of the camera.
    댓글 쓰기
  2. Sony PlayStation Camera Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Sony PlayStation Camera Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
    댓글 쓰기
  3. Sony PlayStation Camera Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using tweezers, remove the cap holding the cable grommet in place.
    댓글 쓰기
  4. Sony PlayStation Camera Motherboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using the tweezers, remove both poly-carbonate lens coverplates.
    • Lift the coverplates slowly, to ensure they do not crack, or break.
    댓글 쓰기
  5. Sony PlayStation Camera Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Sony PlayStation Camera Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
    댓글 쓰기
  6. Sony PlayStation Camera Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
    • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
    댓글 쓰기
  7. Sony PlayStation Camera Motherboard Replacement: 7 단계, 이미지 2개 중 1개 Sony PlayStation Camera Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
    댓글 쓰기
  8. Sony PlayStation Camera Motherboard Replacement: 8 단계, 이미지 3개 중 1개 Sony PlayStation Camera Motherboard Replacement: 8 단계, 이미지 3개 중 2개 Sony PlayStation Camera Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • Lift the motherboard and frame from the plastic housing.
    • Disconnect the camera cable from the motherboard.
    댓글 쓰기
  9. Sony PlayStation Camera Motherboard Replacement: 9 단계, 이미지 2개 중 1개 Sony PlayStation Camera Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
    댓글 쓰기
  10. Sony PlayStation Camera Motherboard Replacement: 10 단계, 이미지 3개 중 1개 Sony PlayStation Camera Motherboard Replacement: 10 단계, 이미지 3개 중 2개 Sony PlayStation Camera Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joshua Gates
회원 가입일: 02/15/17
268 평판
안내서 2개를 작성함
USF Tampa, Team 5-5, Passmore Spring 2017 USF Tampa, Team 5-5, Passmore Spring 2017 회원
USFT-PASSMORE-S17S5G5
3 회원들
안내서 4개를 작성함
1가이드 댓글
I'm guessing you didn't pin out the cable?
So far I get the following pinout, with one pin with no continuity to I'm assuming my issue is there.
Place both cables so the rounded corners are at the top. The two longer pins on the internal cable will be on the right as you look at it. The PS4 accessory cable end should have the plastic tab carrying the pins at the top as you look at it.
PS4 accessory connector -> Camera internal cable
1 - 7
2 - 1
3 - 2
4 - 3
5 - 4
6 - 5? - broken in my cable or no connection by default
7 - 6
Hope that helps someone.
infiniti25 - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 40
전체 시간: 3,057
