주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Reader Touch Edition PRS-600 Power Button Replacement
필요한 것
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      댓글 쓰기
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: 2 단계, 이미지 1개 중 1개
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      댓글 쓰기
    3. Sony Reader Touch Edition PRS-600 Power Button Replacement: 3 단계, 이미지 1개 중 1개
      • This is what the device should look like once the back cover panel has been removed.
      댓글 쓰기
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Battery: 4 단계, 이미지 1개 중 1개
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      댓글 쓰기
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: 5 단계, 이미지 1개 중 1개
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      댓글 쓰기
    1. Sony Reader Touch Edition PRS-600 Power Button Replacement, Power Button: 6 단계, 이미지 1개 중 1개
      • Remove the stylus from the device.
      댓글 쓰기
    2. Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 1개 Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 2개 Sony Reader Touch Edition PRS-600 Power Button Replacement: 7 단계, 이미지 3개 중 3개
      • Using the Phillips screwdriver remove the 1.4 mm screw from the top panel.
      • Using the same screwdriver, remove the 1.4 mm screw from the back of the device.
      • Pry apart off the top panel of the device.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Zachary Jeffers
회원 가입일: 10/13/14
412 평판
안내서 4개를 작성함
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 회원
CLEM-BENSON-F14S1G4
4 회원들
안내서 77개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 63
전체 시간: 1,082
