주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony SRS-XB30 Wires Replacement
필요한 것
    1. Sony SRS-XB30 Wires Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • To remove the speaker grill, insert the big spudger underneath it in each corner.
      • Work around the edges to pry the grill up and off.
      댓글 쓰기
    2. Sony SRS-XB30 Wires Replacement: 2 단계, 이미지 2개 중 1개 Sony SRS-XB30 Wires Replacement: 2 단계, 이미지 2개 중 2개
      • With the Sony logo facing towards you, use the medium spudger to lift the side plates from the internal frame.
      • This will need to be done on all four sides of the speaker to remove all four panels
      • This requires some effort because the adhesive is sticky.
      댓글 쓰기
    3. Sony SRS-XB30 Wires Replacement: 3 단계, 이미지 2개 중 1개 Sony SRS-XB30 Wires Replacement: 3 단계, 이미지 2개 중 2개
      • Locate the four screws on the now exposed front panel.
      • Using the screwdriver with bit T7, unscrew each screw (15.0 mm long).
      댓글 쓰기
    4. Sony SRS-XB30 Wires Replacement: 4 단계, 이미지 1개 중 1개
      • Next, remove the four outer edge screws, located on each corner of the speaker. The outer edge of the speaker is a clear plastic.
      • Use the same T7 screwdriver head here.
      • Remove each of the four corner screws (15.0 mm long).
      댓글 쓰기
    5. Sony SRS-XB30 Wires Replacement: 5 단계, 이미지 1개 중 1개
      • With a little force, carefully lift the lid of the speaker.
      • Make sure that you do not pull on the wires.
      댓글 쓰기
    6. Sony SRS-XB30 Wires Replacement: 6 단계, 이미지 3개 중 1개 Sony SRS-XB30 Wires Replacement: 6 단계, 이미지 3개 중 2개 Sony SRS-XB30 Wires Replacement: 6 단계, 이미지 3개 중 3개
      • Unclip the four wire connectors (that are attached to the speaker lid).
      • Disconnect the thin yellow wire (attached to the speaker lid) from its port.
      댓글 쓰기
    7. Sony SRS-XB30 Wires Replacement: 7 단계, 이미지 1개 중 1개
      • Separate the speaker lid from the bottom frame.
      • To prepare the speaker for the next step place the lid parallel to the frame.
      댓글 쓰기
    8. Sony SRS-XB30 Wires Replacement: 8 단계, 이미지 1개 중 1개
      • Locate the two silver screws (9 mm) attached to the two LED-light-chips on the speaker lid.
      • Using the screwdriver with bit PH1, unscrew each screw.
      댓글 쓰기
    9. Sony SRS-XB30 Wires Replacement: 9 단계, 이미지 1개 중 1개
      • Separate the speaker lid entirely from the bottom frame.
      댓글 쓰기
    10. Sony SRS-XB30 Wires Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the top screw (10 mm).
      • Use the screwdriver with bit T7.
      댓글 쓰기
    11. Sony SRS-XB30 Wires Replacement: 11 단계, 이미지 2개 중 1개 Sony SRS-XB30 Wires Replacement: 11 단계, 이미지 2개 중 2개
      • Locate and remove the three black screws (10.0 mm) within the internal frame. Use bit T7.
      • There are two screws on the left side of the white box and one to its right.
      댓글 쓰기
    12. Sony SRS-XB30 Wires Replacement: 12 단계, 이미지 1개 중 1개
      • Slightly lift the white box with all the wires still attached.
      댓글 쓰기
    13. Sony SRS-XB30 Wires Replacement: 13 단계, 이미지 2개 중 1개 Sony SRS-XB30 Wires Replacement: 13 단계, 이미지 2개 중 2개
      • Take the big spudger and pry the black casing up from the circuit box.
      댓글 쓰기
    14. Sony SRS-XB30 Wires Replacement: 14 단계, 이미지 1개 중 1개
      • Locate the blue film attached to the circuit box containing the charging port.
      • Detach the blue film from the box.
      댓글 쓰기
    15. Sony SRS-XB30 Wires Replacement: 15 단계, 이미지 1개 중 1개
      • Detach the yellow, black and red wires by pulling them directly up.
      댓글 쓰기
    16. Sony SRS-XB30 Wires Replacement: 16 단계, 이미지 2개 중 1개 Sony SRS-XB30 Wires Replacement: 16 단계, 이미지 2개 중 2개
      • Insert the spudger along the battery edge and firmly hold the wires. Lift both sides up. The battery will pop out from its encasement.
      댓글 쓰기
    1. Sony SRS-XB30 Wires Replacement, Wires: 17 단계, 이미지 1개 중 1개
      • Locate the black, yellow, and red wires and steadily pull them smooth if they are tangled.
      댓글 쓰기
    2. Sony SRS-XB30 Wires Replacement: 18 단계, 이미지 1개 중 1개
      • Unravel any tangled wires or replace any damaged wires.
      • The wires should all run parallel to one another.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Isabella Durazo
회원 가입일: 04/09/18
844 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 35
전체 시간: 1,908
