주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony VAIO PCG-3E2L Battery Replacement
필요한 것
  1. Sony VAIO PCG-3E2L Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • First, locate the battery compartment found at the top, underneath the machine.
    • Use your thumbs to push the switch locks inward.
    댓글 쓰기
  2. Sony VAIO PCG-3E2L Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Upon removing the cover you will be met with the current battery.
    • Take note of the orientation of the current battery and carefully locate the lock switch at the middle bottom of the battery and remove it, then set the replacement battery inside the reverse way you removed the old one to install it.
    댓글 쓰기
  3. Sony VAIO PCG-3E2L Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Replace the battery while holding the lock switches inward to install it securely.
    • Check to make sure the lock switch are back into the lock position and the battery cover is flush with the rest of the laptop frame.
    • Now you are able to safely plug back in your charger to test the battery.
    댓글 쓰기
결론
All that is required is for you to power off your laptop and disconnect it from any power source, then flip it around to open the battery cover using the lock switches with both thumbs, then swap the battery in the same orientation and install back the battery cover and secure it with the lock switches before resuming normal operations.
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Chengyang Chen
회원 가입일: 03/27/15
970 평판
안내서 5개를 작성함
UMass Dartmouth, Team 5-2, Kish Spring 2015 UMass Dartmouth, Team 5-2, Kish Spring 2015 회원
UMASSD-KISH-S15S5G2
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 29
전체 시간: 1,867
