주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony VAIO PCG-933A Keyboard Replacement
필요한 것
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    댓글 쓰기
  2. Sony VAIO PCG-933A Keyboard Replacement: 2 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Keyboard Replacement: 2 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Keyboard Replacement: 2 단계, 이미지 3개 중 3개
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    댓글 쓰기
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
    댓글 쓰기
  4. Sony VAIO PCG-933A Keyboard Replacement: 4 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Keyboard Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
    댓글 쓰기
  5. Sony VAIO PCG-933A Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the computer so the key board is facing up.
    댓글 쓰기
  6. Sony VAIO PCG-933A Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
    댓글 쓰기
  7. Sony VAIO PCG-933A Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
9다른 기여자 명과 함께
Sara Lillard
회원 가입일: 04/11/11
165 평판
안내서 8개를 작성함
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 회원
CPSU-MANESS-S11S12G36
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 36
전체 시간: 2,226
