주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony VAIO PCG-933A Thermal Paste Replacement
필요한 것
  1. Sony VAIO PCG-933A Thermal Paste Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    댓글 쓰기
  2. Sony VAIO PCG-933A Thermal Paste Replacement: 2 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 2 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Thermal Paste Replacement: 2 단계, 이미지 3개 중 3개
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    댓글 쓰기
  3. Sony VAIO PCG-933A Thermal Paste Replacement, Keyboard: 3 단계, 이미지 1개 중 1개
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
    댓글 쓰기
  4. Sony VAIO PCG-933A Thermal Paste Replacement: 4 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
    댓글 쓰기
  5. Sony VAIO PCG-933A Thermal Paste Replacement: 5 단계, 이미지 1개 중 1개
    • Flip the computer so the key board is facing up.
    댓글 쓰기
  6. Sony VAIO PCG-933A Thermal Paste Replacement: 6 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 6 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Thermal Paste Replacement: 6 단계, 이미지 3개 중 3개
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
    댓글 쓰기
  7. Sony VAIO PCG-933A Thermal Paste Replacement: 7 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 7 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Thermal Paste Replacement: 7 단계, 이미지 3개 중 3개
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
    댓글 쓰기
  8. Sony VAIO PCG-933A Thermal Paste Replacement, Thermal Paste: 8 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement, Thermal Paste: 8 단계, 이미지 2개 중 2개
    • Remove the two 4mm Phillips screws in the center of the computer located on each side of the copper electrical strip.
    댓글 쓰기
  9. Sony VAIO PCG-933A Thermal Paste Replacement: 9 단계, 이미지 3개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 9 단계, 이미지 3개 중 2개 Sony VAIO PCG-933A Thermal Paste Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the four 4mm Phillips screws around the hard drive cage.
    • WARNING: DVD drive is now loose as well.
    • Lift hard drive cage straight up.
    • Carefully disconnect the copper strip to pull out the hard drive.
    댓글 쓰기
  10. Sony VAIO PCG-933A Thermal Paste Replacement: 10 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 10 단계, 이미지 2개 중 2개
    • With the hard drive removed, unscrew the four 6mm brass colored, Phillips screws under the hard drive cage
    • This will allow you to remove the hard drive mounting bracket
    댓글 쓰기
  11. Sony VAIO PCG-933A Thermal Paste Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 6mm brass colored, Phillips screws that hold the fan cage in place.
    댓글 쓰기
  12. Sony VAIO PCG-933A Thermal Paste Replacement: 12 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the two 4mm black Phillips screws shown here.
    • Remove the 18mm silver Phillips screw shown here.
    • Now remove the silver tab.
    댓글 쓰기
  13. Sony VAIO PCG-933A Thermal Paste Replacement: 13 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 13 단계, 이미지 2개 중 2개
    • Remove the blue and red fan power cords.
    댓글 쓰기
  14. Sony VAIO PCG-933A Thermal Paste Replacement: 14 단계, 이미지 2개 중 1개 Sony VAIO PCG-933A Thermal Paste Replacement: 14 단계, 이미지 2개 중 2개
    • Carefully pull up and out on the metal heat sink and fan bracket.
    • You should be able to see the thermal paste.
    댓글 쓰기
  15. Sony VAIO PCG-933A Thermal Paste Replacement: 15 단계, 이미지 1개 중 1개
    • To remove thermal paste thoroughly, put isopropyl alcohol (70% or greater) on a paper towel and wipe thermal paste off. Some force may be required.
    • Apply new thermal paste to CPU.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Sara Lillard
회원 가입일: 04/11/11
165 평판
안내서 8개를 작성함
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 회원
CPSU-MANESS-S11S12G36
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 47
전체 시간: 4,716
