주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony VAIO VPC-EB33FM Hard Drive Replacement
필요한 것
  1. Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
    댓글 쓰기
  2. Sony VAIO VPC-EB33FM Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • To release the battery, hold both the release button and the unlock button at the same time.
    댓글 쓰기
  3. Sony VAIO VPC-EB33FM Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the battery out from the notch while continuing to hold the release button.
    댓글 쓰기
  4. Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 2개 Sony VAIO VPC-EB33FM Hard Drive Replacement, Hard Drive: 4 단계, 이미지 3개 중 3개
    • Use a Phillips #00 screwdriver to remove the two 7.8 mm cover screws on the bottom corners of the panel.
    댓글 쓰기
  5. Sony VAIO VPC-EB33FM Hard Drive Replacement: 5 단계, 이미지 3개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement: 5 단계, 이미지 3개 중 2개 Sony VAIO VPC-EB33FM Hard Drive Replacement: 5 단계, 이미지 3개 중 3개
    • Use a finger/fingernail to grip the notch at the bottom of the panel to lift it off.
    • You may need to use your other hand to safely remove the panel.
    • You can also use a spudger for this step.
    댓글 쓰기
  6. Sony VAIO VPC-EB33FM Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the two remaining 7.8 mm screws using the Phillips #00 screwdriver.
    댓글 쓰기
  7. Sony VAIO VPC-EB33FM Hard Drive Replacement: 7 단계, 이미지 1개 중 1개
    • Grab the tab between your thumb and index finger.
    • Hold the hard drive securely in a horizontal position using your other hand.
    • Push the hard drive to the left using the plastic tab to disconnect it from the laptop.
    • To prevent damage of the connection on the hard disk drive or the laptop, perform this task slowly and with care.
    댓글 쓰기
  8. Sony VAIO VPC-EB33FM Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • While still holding the plastic tab, lift the right side of the hard drive out at a 45º angle.
    • Pull the hard drive out.
    댓글 쓰기
  9. Sony VAIO VPC-EB33FM Hard Drive Replacement: 9 단계, 이미지 2개 중 1개 Sony VAIO VPC-EB33FM Hard Drive Replacement: 9 단계, 이미지 2개 중 2개
    • If you need to remove the bracket from the hard drive, follow the next few steps:
    • Remove the two 3.7 mm screws from either side of the bracket with a Phillips #00 screwdriver.
    • Lift the bracket off the hard drive.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Christian
회원 가입일: 01/14/13
195 평판
안내서 1개를 작성함
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 회원
CPSU-REGAN-W13S18G39
5 회원들
안내서 15개를 작성함
1가이드 댓글
This is very good step by step instructions guide. Loved it and was able to remove my laptop hd very easily. I created this account only to say thanks to writer. Amazing job !! Thaks ton.
Dinesh - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 19,090
