주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony VAIO VPCEE26FX Keyboard Replacement
필요한 것
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
    댓글 쓰기
  2. Sony VAIO VPCEE26FX Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Sony VAIO VPCEE26FX Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
    댓글 쓰기
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 1개 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 3 단계, 이미지 2개 중 2개
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
    댓글 쓰기
  4. Sony VAIO VPCEE26FX Keyboard Replacement: 4 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
    댓글 쓰기
  5. Sony VAIO VPCEE26FX Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Sony VAIO VPCEE26FX Keyboard Replacement: 5 단계, 이미지 2개 중 2개
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
    댓글 쓰기
  6. Sony VAIO VPCEE26FX Keyboard Replacement: 6 단계, 이미지 2개 중 1개 Sony VAIO VPCEE26FX Keyboard Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
    댓글 쓰기
  7. Sony VAIO VPCEE26FX Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    댓글 쓰기
  8. Sony VAIO VPCEE26FX Keyboard Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the keyboard up and away from the computer.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Christopher Hover
회원 가입일: 03/21/19
679 평판
안내서 5개를 작성함
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G3
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 1,584
