주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio VGN-FS640 Keyboard Replacement
필요한 것
  1. Sony Vaio VGN-FS640 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Lay the closed laptop on its screen so the bottom is facing towards you.
    댓글 쓰기
  2. Sony Vaio VGN-FS640 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • Push both latches towards the center of the battery.
    댓글 쓰기
  3. Sony Vaio VGN-FS640 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
    댓글 쓰기
  4. Sony Vaio VGN-FS640 Keyboard Replacement, RAM Cover: 4 단계, 이미지 2개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement, RAM Cover: 4 단계, 이미지 2개 중 2개
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
    댓글 쓰기
  5. Sony Vaio VGN-FS640 Keyboard Replacement: 5 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 5 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement: 5 단계, 이미지 3개 중 3개
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
    댓글 쓰기
  6. Sony Vaio VGN-FS640 Keyboard Replacement, Hard Drive: 6 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement, Hard Drive: 6 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement, Hard Drive: 6 단계, 이미지 3개 중 3개
    • Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
    • Slide the cover until it is free from the laptop case.
    • Lift the cover to remove.
    댓글 쓰기
  7. Sony Vaio VGN-FS640 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Locate and remove the four screws (Length: 7.7mm) holding the Hard Drive tray in place.
    • Using the tab on the tray, slide the Hard Drive away from the main body of the laptop.
    • The Hard Drive should now be disconnected.
    • Lift the drive out with the tab on the tray.
    댓글 쓰기
  8. Sony Vaio VGN-FS640 Keyboard Replacement, Back Cover: 8 단계, 이미지 1개 중 1개
    • Locate the screws highlighted here. There are 16 total.
    • Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
    댓글 쓰기
  9. Sony Vaio VGN-FS640 Keyboard Replacement: 9 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 9 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement: 9 단계, 이미지 3개 중 3개
    • Before you proceed, make sure you pay special attention to the way the small plastic part that covers the radiator fins is held in place. You will need to know how it attaches when you reassemble the laptop.
    • You do not need to actually remove the part at this time. It is held in place by the rest of the back cover and will fall off when back cover is removed in the next step.
    댓글 쓰기
  10. Sony Vaio VGN-FS640 Keyboard Replacement: 10 단계, 이미지 2개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 10 단계, 이미지 2개 중 2개
    • After removing the screws, use your fingers to lift the back cover off the laptop.
    댓글 쓰기
  11. Sony Vaio VGN-FS640 Keyboard Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the back cover and place it somewhere safe so you can locate it later.
    댓글 쓰기
  12. Sony Vaio VGN-FS640 Keyboard Replacement, Keyboard: 12 단계, 이미지 1개 중 1개
    • After the back cover is removed, lay the laptop on a flat surface, with the bottom facing up.
    댓글 쓰기
  13. Sony Vaio VGN-FS640 Keyboard Replacement: 13 단계, 이미지 2개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 13 단계, 이미지 2개 중 2개
    • To remove the keyboard, the speaker cover must be removed first.
    • To do this, first remove the two screws (Length: 2.3 mm) highlighted in the picture.
    댓글 쓰기
  14. Sony Vaio VGN-FS640 Keyboard Replacement: 14 단계, 이미지 1개 중 1개
    • After the screws are removed, flip the laptop over so the keyboard is facing up and move the screen to its upright position.
    댓글 쓰기
  15. Sony Vaio VGN-FS640 Keyboard Replacement: 15 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 15 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement: 15 단계, 이미지 3개 중 3개
    • To start removing the speaker cover, use your finger to lift up on the exposed corner of the black speaker cover, located near the bottom left corner of the screen.
    • Slowly pull the speaker cover off from left to right, making sure it snaps off little by little.
    댓글 쓰기
  16. Sony Vaio VGN-FS640 Keyboard Replacement: 16 단계, 이미지 1개 중 1개
    • After removing the speaker cover, remove the four screws (Length: 3.6 mm) with your Phillips #0 screwdriver that hold the keyboard in place.
    댓글 쓰기
  17. Sony Vaio VGN-FS640 Keyboard Replacement: 17 단계, 이미지 1개 중 1개
    • Lift the free edge of the keyboard and fold it back to expose the ribbon that connects the keyboard to the laptop.
    • The large silver surface you see at the bottom of the picture is the back of the keyboard.
    댓글 쓰기
  18. Sony Vaio VGN-FS640 Keyboard Replacement: 18 단계, 이미지 3개 중 1개 Sony Vaio VGN-FS640 Keyboard Replacement: 18 단계, 이미지 3개 중 2개 Sony Vaio VGN-FS640 Keyboard Replacement: 18 단계, 이미지 3개 중 3개
    • On each side of the white plastic connector, there is a tiny black tab that locks the ribbon into place.
    • Use the sharp edge of a spudger to slide the black tabs away from from the white plastic connector.
    • Once the tabs have been extended away from the connector, the ribbon can be removed from the keyboard.
    • The keyboard is now completely disconnected from the laptop.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Michael Maravick
회원 가입일: 04/15/10
75 평판
안내서 2개를 작성함
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 회원
CPSU-REGAN-S10S24G32
4 회원들
안내서 16개를 작성함
1가이드 댓글
You only need to remove the 2 screws in the battery compartment to complete this replacement. The student may be brilliant but he sure enjoys doing unnecessarily long, overly complex, and potentially damaging tasks. ;-)
Empire Computer Repair - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 46
전체 시간: 19,195
