주요 콘텐츠로 건너뛰기
Sony Vaio VGN-FS640 RAM Replacement
필요한 것
  1. Sony Vaio VGN-FS640 RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Lay the closed laptop on its screen so the bottom is facing towards you.
  2. Sony Vaio VGN-FS640 RAM Replacement: 2 단계, 이미지 1/1
    • Push both latches towards the center of the battery.
  3. Sony Vaio VGN-FS640 RAM Replacement: 3 단계, 이미지 1/2 Sony Vaio VGN-FS640 RAM Replacement: 3 단계, 이미지 2/2
    • Revome the battery by pushing it away from the laptop.
    • Set the battery away from the laptop.
  4. Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: 4 단계, 이미지 1/2 Sony Vaio VGN-FS640 RAM Replacement, RAM Cover: 4 단계, 이미지 2/2
    • With the bottom of the laptop facing up, locate the RAM cover.
    • The RAM is covered by the panel with four columns of vents.
    • Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
  5. Sony Vaio VGN-FS640 RAM Replacement: 5 단계, 이미지 1/3 Sony Vaio VGN-FS640 RAM Replacement: 5 단계, 이미지 2/3 Sony Vaio VGN-FS640 RAM Replacement: 5 단계, 이미지 3/3
    • Use your fingers to slide the cover away from the laptop. (It will only slide a few millimeters)
    • Once the panel is out of its locked position, it can be lifted out without any resistance.
  6. Sony Vaio VGN-FS640 RAM Replacement, RAM: 6 단계, 이미지 1/3 Sony Vaio VGN-FS640 RAM Replacement, RAM: 6 단계, 이미지 2/3 Sony Vaio VGN-FS640 RAM Replacement, RAM: 6 단계, 이미지 3/3
    • To remove the RAM, use sharp end of a spudger to push the two silver tabs (see picture) away from the green RAM chip.
    • When both silver tabs are moved to the side, one edge of the RAM chip will pop up from its original position.
    • Use your fingers to grab the raised edge of the RAM and pull the chip away from its connection to the laptop.
  7. Sony Vaio VGN-FS640 RAM Replacement: 7 단계, 이미지 1/1
    • To install the new RAM, grip the new chip exactly the same way as you gripped the old chip when you removed it.
    • Insert the gold leads of the RAM into the connection at the same angle the original chip was raised at after the tabs were released.
    • There is a raised tab on the connection that mates with a slit in the RAM to ensure you do not put the chip in upside down.
  8. Sony Vaio VGN-FS640 RAM Replacement: 8 단계, 이미지 1/1
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Michael Maravick
회원 가입일: 04/15/10
75 평판
안내서 2개 작성하였습니다
Cal Poly, Team 24-32, Regan Spring 2010 Cal Poly, Team 24-32, Regan Spring 2010 회원
CPSU-REGAN-S10S24G32
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 18
전체 시간: 10,386
