주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio VPCCW17FX Fan Replacement
필요한 것
  1. Sony Vaio VPCCW17FX Fan Replacement, Back case: 1 단계, 이미지 1개 중 1개
    • Turn the laptop over and orient it as shown.
    댓글 쓰기
  2. Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 3개 중 1개 Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 3개 중 2개 Sony Vaio VPCCW17FX Fan Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
    댓글 쓰기
  3. Sony Vaio VPCCW17FX Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
    댓글 쓰기
  4. Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 3개 중 1개 Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 3개 중 2개 Sony Vaio VPCCW17FX Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
    댓글 쓰기
  5. Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 3개 중 1개 Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 3개 중 2개 Sony Vaio VPCCW17FX Fan Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
    댓글 쓰기
  6. Sony Vaio VPCCW17FX Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
    댓글 쓰기
  7. Sony Vaio VPCCW17FX Fan Replacement: 7 단계, 이미지 1개 중 1개
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
    댓글 쓰기
  8. Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 3개 중 1개 Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 3개 중 2개 Sony Vaio VPCCW17FX Fan Replacement, Fan: 8 단계, 이미지 3개 중 3개
    • Locate the fan (top-right corner of the computer).
    • Using a Phillips #00 screwdriver, unscrew the six 2.7 mm screws that secure the fan to the motherboard.
    댓글 쓰기
  9. Sony Vaio VPCCW17FX Fan Replacement: 9 단계, 이미지 2개 중 1개 Sony Vaio VPCCW17FX Fan Replacement: 9 단계, 이미지 2개 중 2개
    • This step can be skipped if you are just removing the fan to access another part of the device (such as the motherboard).
    • Using a Japanese Industrial Standard #00 screwdriver, unscrew four 3.7 mm screws located on the casing of the fan.
    댓글 쓰기
  10. Sony Vaio VPCCW17FX Fan Replacement: 10 단계, 이미지 2개 중 1개 Sony Vaio VPCCW17FX Fan Replacement: 10 단계, 이미지 2개 중 2개
    • Using your fingers, grasp the white tab and firmly, yet gently, pull up on the wire to disconnect it from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Ellie DePorter
회원 가입일: 01/29/18
310 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 23
전체 시간: 1,455
