주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Vaio VPCW211AX RAM Replacement
필요한 것
  1. Sony Vaio VPCW211AX RAM  Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Start with the laptop face up on a flat surface.
    댓글 쓰기
  2. Sony Vaio VPCW211AX RAM  Replacement: 2 단계, 이미지 1개 중 1개
    • Open the laptop with the keyboard facing you.
    댓글 쓰기
  3. Sony Vaio VPCW211AX RAM  Replacement: 3 단계, 이미지 2개 중 1개 Sony Vaio VPCW211AX RAM  Replacement: 3 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
    댓글 쓰기
  4. Sony Vaio VPCW211AX RAM  Replacement: 4 단계, 이미지 2개 중 1개 Sony Vaio VPCW211AX RAM  Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
    댓글 쓰기
  5. Sony Vaio VPCW211AX RAM  Replacement, RAM: 5 단계, 이미지 1개 중 1개
    • Use a Philips #0 screwdriver to remove the 7 top case screws.
    댓글 쓰기
  6. Sony Vaio VPCW211AX RAM  Replacement: 6 단계, 이미지 1개 중 1개
    • Using a metal spudger, pry open at the seams.
    • Open the gray top of the laptop from the base black portion.
    • Slide the spudger along the seam, and then carefully open the top.
    댓글 쓰기
  7. Sony Vaio VPCW211AX RAM  Replacement: 7 단계, 이미지 2개 중 1개 Sony Vaio VPCW211AX RAM  Replacement: 7 단계, 이미지 2개 중 2개
    • Open the top carefully without disconnecting the two parts.
    • Be mindful and careful of the ribbon cable attaching the two parts together.
    댓글 쓰기
  8. Sony Vaio VPCW211AX RAM  Replacement: 8 단계, 이미지 2개 중 1개 Sony Vaio VPCW211AX RAM  Replacement: 8 단계, 이미지 2개 중 2개
    • Using your fingers, pry apart the two side metal pieces that hold the part in place as shown on the picture.
    댓글 쓰기
  9. Sony Vaio VPCW211AX RAM  Replacement: 9 단계, 이미지 1개 중 1개
    • After that step, the RAM should pop up on its own as shown in the picture.
    댓글 쓰기
  10. Sony Vaio VPCW211AX RAM  Replacement: 10 단계, 이미지 2개 중 1개 Sony Vaio VPCW211AX RAM  Replacement: 10 단계, 이미지 2개 중 2개
    • Carefully press the sides near the right edge of the part and remove it from it's base.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Giselle Dougan
회원 가입일: 01/31/18
760 평판
안내서 5개를 작성함
1가이드 댓글
I have a 21212L and you have to remove the screws under the flap to remove the keyboard firstm you also do not have to remove the top assembly at all.
Samuel Gottschall - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 1,194
