주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM4 Battery Replacement
필요한 것
    1. Sony WH-1000XM4 Battery Replacement, Place the headphones speakers-up: 1 단계, 이미지 1개 중 1개
      • Before beginning any repairs, press and hold the power button on the left ear cup for about 2 seconds until the blue light turns off.
      • Place your headphones onto a work surface, ear pads facing up.
      댓글 쓰기
    1. Sony WH-1000XM4 Battery Replacement, Create a gap: 2 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Create a gap: 2 단계, 이미지 2개 중 2개
      • Use your thumb to depress the RIGHT ear pad near the long outer edge, creating a gap between the cushion and the frame.
      댓글 쓰기
    2. Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: 3 단계, 이미지 3개 중 1개 Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: 3 단계, 이미지 3개 중 2개 Sony WH-1000XM4 Battery Replacement, Unclip the ear cup: 3 단계, 이미지 3개 중 3개
      • Insert the flat end of a spudger into the gap you've created, between the edge of the cushion and the frame.
      • Pivot the spudger down to unclip the long edge of the ear pad.
      • When the first clip disconnects, you'll hear an audible clicking sound.
      • This may take a considerable amount of force. If the cushion won't click out of place, move your spudger to different points along the long edge.
      댓글 쓰기
    3. Sony WH-1000XM4 Battery Replacement: 4 단계, 이미지 3개 중 1개 Sony WH-1000XM4 Battery Replacement: 4 단계, 이미지 3개 중 2개 Sony WH-1000XM4 Battery Replacement: 4 단계, 이미지 3개 중 3개
      • Repeat the previous step around the perimeter of the ear cup to disconnect the remaining clips.
      댓글 쓰기
    4. Sony WH-1000XM4 Battery Replacement, Remove the ear pad: 5 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Remove the ear pad: 5 단계, 이미지 2개 중 2개
      • Remove the right ear pad.
      댓글 쓰기
    5. Sony WH-1000XM4 Battery Replacement, Reassembly tip: 6 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Reassembly tip: 6 단계, 이미지 2개 중 2개
      • When installing a replacement right ear pad:
      • Align the cushion over the speaker and press them firmly together to snap it into place.
      • Press around the entire edge of the cushion, making sure all the clips have engaged.
      댓글 쓰기
    1. Sony WH-1000XM4 Battery Replacement, Remove the foam liner: 7 단계, 이미지 1개 중 1개
      • Remove the foam liner from the right ear cup's speaker.
      댓글 쓰기
    2. Sony WH-1000XM4 Battery Replacement, Remove the ear cup cover screws: 8 단계, 이미지 1개 중 1개
      • Use a Phillips screwdriver to remove the four 8.4 mm screws securing the right ear cup cover.
      댓글 쓰기
    3. Sony WH-1000XM4 Battery Replacement, Flip out the cover: 9 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Flip out the cover: 9 단계, 이미지 2개 중 2개
      • Flip the headphones over, ear cups facing down.
      • Use your fingers to lift up and flip over the right ear cup cover.
      • Don't try to completely remove the cover just yet—it's still attached with the touch cable.
      댓글 쓰기
    4. Sony WH-1000XM4 Battery Replacement, Remove the right ear cup cover: 10 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Remove the right ear cup cover: 10 단계, 이미지 2개 중 2개
      • Grip the touch ribbon cable and pull it straight out of its connector on the main board to remove it.
      • Remove the ear cup cover.
      댓글 쓰기
    5. Sony WH-1000XM4 Battery Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement, Disconnect the battery: 11 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Warning: Over time, this connector can become brittle. Go slowly, and try to hold the off-white connector to the board as you work. Don't use excessive force, or you risk pulling the connector off of the board and breaking the fragile solder joints.
      • Use a pair of tweezers to grip the edges of the battery connector, and pull up to disconnect it from the main board. If necessary, lever the connector out, or "walk" the tweezer arms side-to-side to release the connector from its socket.
      • Always pull cables by their connectors and not the wires themselves.
      댓글 쓰기
    6. Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: 12 단계, 이미지 3개 중 1개 Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: 12 단계, 이미지 3개 중 2개 Sony WH-1000XM4 Battery Replacement, Remove the thermal sensor: 12 단계, 이미지 3개 중 3개
      • If your replacement battery doesn't come with a thermal sensor preinstalled, you'll need to transfer your old one over from your old battery.
      • Whenever you use tweezers near the battery, be very careful not to puncture the battery.
      • Use a pair of tweezers to peel back the foam and adhesive covering the battery thermal sensor.
      • During reinstallation, make sure the diode on the end of the thermal sensor flex cable is facing up.
      댓글 쓰기
    7. Sony WH-1000XM4 Battery Replacement: 13 단계, 이미지 2개 중 1개 Sony WH-1000XM4 Battery Replacement: 13 단계, 이미지 2개 중 2개
      • Use a pair of tweezers to pull up on the thermal sensor ribbon cable to disconnect it from the main board.
      • Pull only on the darker pull-tab section of the cable, not the cable itself.
      • Remove the thermal sensor.
      댓글 쓰기
    8. Sony WH-1000XM4 Battery Replacement, Pry up the battery: 14 단계, 이미지 3개 중 1개 Sony WH-1000XM4 Battery Replacement, Pry up the battery: 14 단계, 이미지 3개 중 2개 Sony WH-1000XM4 Battery Replacement, Pry up the battery: 14 단계, 이미지 3개 중 3개
      • Slide the flat end of a spudger under the top-lefthand corner of the battery.
      • Push the spudger underneath the battery, prying up intermittently to work the battery away from its adhesive.
      댓글 쓰기
    9. Sony WH-1000XM4 Battery Replacement, Remove the battery: 15 단계, 이미지 3개 중 1개 Sony WH-1000XM4 Battery Replacement, Remove the battery: 15 단계, 이미지 3개 중 2개 Sony WH-1000XM4 Battery Replacement, Remove the battery: 15 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      Tesa 61395 Tape
      $8.95
      • Remove the battery.
      • Don't reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
      • To install a new battery:
      • Remove any remaining adhesive from the battery well.
      • If your replacement battery does not come with replacement adhesive, lay some double-sided tape or pre-cut adhesive strips in the headphone's battery well.
      • Peel away any tape liners to expose the adhesive.
      • Lay the battery on the adhesive and press firmly.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or search our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
다른 50명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Carsten Frauenheim
회원 가입일: 03/10/20
167,990 평판
안내서 439개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 41,457개를 작성함
14가이드 댓글
You can also get the battery from sony’s site!
https://sony.encompass.com/item/11687300...
Will - 답글 공유
Is this a xm3 or an xm4 battery?
David Kobura Sandberg - 답글 공유
In reply to the previous comment, that is NOT “sony’s site”. Encompass is not Sony! They distribute parts for hundreds of different brands, not just Sony. I’m not saying there’s anything wrong with them but don’t mislead people into thinking they’re buying directly from Sony!
Haitham - 답글 공유
Thanks for this guide. I was able to repair a loose cable on my XM3s with this disassembly information.
Since the design of the models are mostly the same it would be nice to have a similar disassembly guide on the XM3 website too.
X West - 답글 공유
como puedo adquirir la batería con el sensor térmico preinstalado de los audífonos sony wh1000xm4 ????? avisarme a josephchr_est@hotmail.com
Dental Service - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 79
지난 7일: 603
지난 30일: 2,712
전체 시간: 229,844
