주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Walkman D-E356CK Disk Reader Replacement
필요한 것
    1. Sony Walkman D-E356CK Disk Reader Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
      • Open the battery compartment.
      • Remove the AA batteries from within the compartment.
      댓글 쓰기
    2. Sony Walkman D-E356CK Disk Reader Replacement: 2 단계, 이미지 3개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement: 2 단계, 이미지 3개 중 2개 Sony Walkman D-E356CK Disk Reader Replacement: 2 단계, 이미지 3개 중 3개
      • Press the button located in the bottom left corner of the device labeled "open."
      • Remove the three 11 mm-long Phillips screws.
      댓글 쓰기
    3. Sony Walkman D-E356CK Disk Reader Replacement: 3 단계, 이미지 2개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the two 11 mm-long Phillips screws on the back side of the Walkman.
      댓글 쓰기
    4. Sony Walkman D-E356CK Disk Reader Replacement: 4 단계, 이미지 2개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement: 4 단계, 이미지 2개 중 2개
      • Insert an opening tool into the seam between the back panel and chassis.
      • Pry around the perimeter until the back panel releases.
      • Remove the back panel.
      댓글 쓰기
    1. Sony Walkman D-E356CK Disk Reader Replacement, Motherboard: 5 단계, 이미지 3개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement, Motherboard: 5 단계, 이미지 3개 중 2개 Sony Walkman D-E356CK Disk Reader Replacement, Motherboard: 5 단계, 이미지 3개 중 3개
      • Gently lift the motherboard to reveal the backside of the motherboard.
      • Disconnect the two JST connectors.
      댓글 쓰기
    2. Sony Walkman D-E356CK Disk Reader Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the latch that secures the ribbon cable.
      • Disconnect the ribbon cable.
      댓글 쓰기
    1. Sony Walkman D-E356CK Disk Reader Replacement, Disk Motor: 7 단계, 이미지 3개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement, Disk Motor: 7 단계, 이미지 3개 중 2개 Sony Walkman D-E356CK Disk Reader Replacement, Disk Motor: 7 단계, 이미지 3개 중 3개
      • Remove the disk motor housing from front panel and flip it over.
      • Remove the 5mm screws from the disk motor.
      댓글 쓰기
    1. Sony Walkman D-E356CK Disk Reader Replacement, Disk Reader: 8 단계, 이미지 2개 중 1개 Sony Walkman D-E356CK Disk Reader Replacement, Disk Reader: 8 단계, 이미지 2개 중 2개
      • Carefully take out the clear plastic piece found in the image.
      • Use the tweezers to carefully remove the clear yellow gear.
      댓글 쓰기
    2. Sony Walkman D-E356CK Disk Reader Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the rod with a white gear attached at the end.
      댓글 쓰기
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Andrew Choquette
회원 가입일: 10/15/25
366 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-1, Botvin Fall 2025 UMass Dartmouth, Team 1-1, Botvin Fall 2025 회원
UMASSD-BOTVIN-F25S1G1
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 23
전체 시간: 114
