주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Walkman WM-AF48 Film Revolver Band Replacement
필요한 것
    1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Getting started: 1 단계, 이미지 1개 중 1개
      • Remove any batteries or cassettes from the Walkman.
      댓글 쓰기
    2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 1개 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 2개 Sony Walkman WM-AF48 Film Revolver Band Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 3개
      • Using a spudger, separate the back cover from the front.
      • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
      댓글 쓰기
    1. Sony Walkman WM-AF48 Film Revolver Band Replacement, Replace the band: 3 단계, 이미지 1개 중 1개
      • Replace the band, ensuring that it wraps around both large plastic revolvers and the small metal one.
      댓글 쓰기
    2. Sony Walkman WM-AF48 Film Revolver Band Replacement, Belt track: 4 단계, 이미지 1개 중 1개
      • This picture shows how the belt was set when I opened a Walkman WM-FX10.
      • I think you can rely on the same arrangement in other Walkman's
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Wilson Riforgiat
회원 가입일: 09/11/14
931 평판
안내서 4개를 작성함
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G4
4 회원들
안내서 27개를 작성함
3가이드 댓글
"How to replace the band":
Step 1: Open it.
Step 2: Replace the band.
Really? That's it?! Not very useful.
No Thanks - 답글 공유
I need to know the belt track. I'm thinking there is a particular path the belt must follow. Do you know it? Your photo shows no belt (band).
jcalla704 - 답글 공유
Helped. Wanted an idea of how to open, before breaking it!
Troyf - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 62
전체 시간: 19,817
