주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Walkman WM-AF48 Power Switch Replacement
필요한 것
    1. Sony Walkman WM-AF48 Power Switch Replacement, Getting started: 1 단계, 이미지 1개 중 1개
      • Remove any batteries or cassettes from the Walkman.
      댓글 쓰기
    2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 1개 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 2개 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 2 단계, 이미지 3개 중 3개
      • Using a spudger, separate the back cover from the front.
      • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
      댓글 쓰기
    1. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: 3 단계, 이미지 2개 중 1개 Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: 3 단계, 이미지 2개 중 2개
      • Gently pull the ribbon from the jack above the film revolver, near the edge.
      • Lift the motherboard from the outer shell.
      • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
      댓글 쓰기
    2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the power switch: 4 단계, 이미지 1개 중 1개
      • Identify the six points where the power switch is soldered to the motherboard.
      • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Wilson Riforgiat
회원 가입일: 09/11/14
931 평판
안내서 4개를 작성함
USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-4, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G4
4 회원들
안내서 92개를 작성함
1가이드 댓글
Hi,
Where would you find a Vintage Sports Sony Walkman power switch ? Battery light is on one function and then turns off on the other. Other than this, the unit is in EXCELLENT Condition. THANKS for any insight and for helping us :)
Pamela Osborne - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 40
전체 시간: 2,575
