주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia XZ2 Battery Replacement
필요한 것
    1. Sony Xperia XZ2 Battery Replacement, LCD Screen: 1 단계, 이미지 3개 중 1개 Sony Xperia XZ2 Battery Replacement, LCD Screen: 1 단계, 이미지 3개 중 2개 Sony Xperia XZ2 Battery Replacement, LCD Screen: 1 단계, 이미지 3개 중 3개
      • Weaken the glue that is keeping the screen in place by heating up the edges of the phone with a hair dryer or heat gun.
      • The phone gets very hot and can hurt the user handling it.
      댓글 쓰기
    2. Sony Xperia XZ2 Battery Replacement: 2 단계, 이미지 3개 중 1개 Sony Xperia XZ2 Battery Replacement: 2 단계, 이미지 3개 중 2개 Sony Xperia XZ2 Battery Replacement: 2 단계, 이미지 3개 중 3개
      • Scrape all the glue from the inside edges by inserting opening picks into the bottom edge of the phone and working your way around the edges.
      • If the glue hardens and becomes difficult to move the plastic around the edges, reheat the phone.
      댓글 쓰기
    3. Sony Xperia XZ2 Battery Replacement: 3 단계, 이미지 2개 중 1개 Sony Xperia XZ2 Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Pry open the phone by inserting an opening pick under one of the edges and removing the screen.
      • The screen is still attached by a connector, so do not pull the pieces apart.
      댓글 쓰기
    4. Sony Xperia XZ2 Battery Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      $3.99
      • Remove the bracket covering the connector by grabbing one side of the bracket with angled tweezers and gently pulling it off.
      댓글 쓰기
    5. Sony Xperia XZ2 Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Gently remove the connector by using a spudger to pop it off.
      댓글 쓰기
    1. Sony Xperia XZ2 Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
      • Take out the twelve 3.5mm screws using the Phillips #00 screwdriver.
      • Remove the one 3 mm Phillips #00 screws.
      • Remove the two 1mm Phillips #00 screws.
      • Fifteen screws should be removed in total in this step. (Not all the screws are visible in the picture.)
      댓글 쓰기
    2. Sony Xperia XZ2 Battery Replacement: 7 단계, 이미지 1개 중 1개
      • Lift the metal screen shield out of the phone.
      댓글 쓰기
    3. Sony Xperia XZ2 Battery Replacement: 8 단계, 이미지 3개 중 1개 Sony Xperia XZ2 Battery Replacement: 8 단계, 이미지 3개 중 2개 Sony Xperia XZ2 Battery Replacement: 8 단계, 이미지 3개 중 3개
      • Use the spudger to pry up the battery flex connector to pop the battery out.
      댓글 쓰기
    4. Sony Xperia XZ2 Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Lift the battery out of the phone.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Arti Jain
회원 가입일: 01/24/19
261 평판
안내서 1개를 작성함
Cal Poly, Team S19-G5, White Winter 2019 Cal Poly, Team S19-G5, White Winter 2019 회원
CPSU-WHITE-W19S19G5
4 회원들
안내서 35개를 작성함
1가이드 댓글
لقد كان العمل على هذا الهاتف مريحا جدا و جميل
Mouad Driouch - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 17
지난 7일: 82
지난 30일: 397
전체 시간: 33,252
