주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z Ultra Front Camera Replacement
필요한 것
    1. Sony Xperia Z Ultra Front Camera Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Use the small suction cup to lift the back panel:
      • Press the small suction cup on to the middle of the back panel.
      댓글 쓰기
    2. Sony Xperia Z Ultra Front Camera Replacement: 2 단계, 이미지 1개 중 1개
      • While holding the Sony Xperia Z ultra down with your left hand, slightly pull the small suction cup upwards to create a small opening between the back panel and the front panel.
      • While continuing to pull the small suction cup upwards, insert the spudger in the small opening.
      • Pry the front panel downwards with the spudger while continuing to pull the small suction cup upwards.
      댓글 쓰기
    3. Sony Xperia Z Ultra Front Camera Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the back panel by pulling the small suction cup upwards.
      댓글 쓰기
    4. Sony Xperia Z Ultra Front Camera Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the following six screws with a Phillips #000 screwdriver:
      • five silver 2.1 mm screws
      • one gold 3.1 mm screw
      댓글 쓰기
    5. Sony Xperia Z Ultra Front Camera Replacement: 5 단계, 이미지 1개 중 1개
      • Pry the plastic motherboard shield open by placing the spudger under the shield and running it along the edges.
      댓글 쓰기
    6. Sony Xperia Z Ultra Front Camera Replacement: 6 단계, 이미지 1개 중 1개
      • Use care to remove the motherboard shield, as it may break. The motherboard shield is made of a very thin plastic.
      • Remove the motherboard shield by lifting the lower end upwards first.
      댓글 쓰기
    7. Sony Xperia Z Ultra Front Camera Replacement: 7 단계, 이미지 2개 중 1개 Sony Xperia Z Ultra Front Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Detach the battery connection cable by prying it upward with the spudger.
      댓글 쓰기
    8. Sony Xperia Z Ultra Front Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Pry the upper end of the antenna upwards with the spudger.
      댓글 쓰기
    9. Sony Xperia Z Ultra Front Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Detach the antenna by pulling the upper end upwards and outwards.
      댓글 쓰기
    10. Sony Xperia Z Ultra Front Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Insert the spudger underneath the battery and run it back and forth to remove any adhesive.
      댓글 쓰기
    11. Sony Xperia Z Ultra Front Camera Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the battery from the phone.
      댓글 쓰기
    1. Sony Xperia Z Ultra Front Camera Replacement, Front Camera: 12 단계, 이미지 1개 중 1개
      • Use care to pry the front camera off, as it can easily be damaged if too much force is used. The connection from the front facing camera to the motherboard is delicate.
      • Pry the connection upwards from the motherboard with the spudger to reveal the front facing camera.
      댓글 쓰기
    2. Sony Xperia Z Ultra Front Camera Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the front facing camera by pulling upward on the flap to its right .
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Aaron Quinn
회원 가입일: 10/01/15
930 평판
안내서 3개를 작성함
Cal Poly, Team 4-6, Maness Fall 2015 Cal Poly, Team 4-6, Maness Fall 2015 회원
CPSU-MANESS-F15S4G6
4 회원들
안내서 30개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 26
전체 시간: 2,490
